td42u dizzy with an unchipped P06
I own a 95 EX Coupe with a D16Z6 motor that my son-in-law installed a couple of years back. I've been driving it as my work commuter, but I do like to go fast every once in awhile. I recently discovered that the dizzy is not the original and neither is the ECU. I know the VTEC doesn't work because of this so I'm heading in the direction of getting these things in order, as well as take care of a nasty dizzy oil leak. I have recently purchased an OEM TD-42U dizzy and that brings me to my question. If I install the TD-42U, will the unchipped P06 ECU run it correctly, minus the VTEC? I know I need to chip the P06 or buy a P28 ECU to make the VTEC kick in, but for now, I'd like to stop the oil leak and stab the new dizzy I bought if it will work. You guys are the gurus, lemme know what ya think.
What does the Distributor have to do with the ECU? That is dependant on the head and the OBD you are running. You need an OBD1 ECU that matches the head (and its functionality)
So I suppose the P06 OBD1 ECU is compatible with my cylinder head since I've been running the motor with it for 2 years now. This makes me think the TD-42U would work but that it would not kick in the VTEC, which I've been living without all this time.
The distributor does not control VTEC. you need a P28 or compatible ecu chipped to run the vtec. Additionally if the car did not come with the VTEC enabled you will have to run wiring back to the cabin of the car and connect it to the appropriate pins on said new new/chipped ECU
the internals are all the same for the d and b series dizzys afaik
it will run, just without vtec until you get the proper ecu
the oil leak is usually just the o ring on the distributor unless its in side the cap
If I'm getting all this correct, the TD-42U will work with the P06 but, in it's present form, the P06 ECU will not engage the VTEC.
Now, all I need is someone who can chip the P06 locally and I'd be in business.
I guess I'm in the market for a virgin 5 speed P28 ECU.
