Glowshift wideband with S300v3 how do I connect to ecu?
I'm in process of setting up my car electronically. It's a 99 civic hatch with an ITR kraftwerks setup. I have a Rywire harness too and this is my 1st time installing a wideband.
What I'm asking for help on is how do I wire the wideband to s300 and what settings do I have to go under to get it to recognize it? It's a bosh sensor #17025.
All guides I find are for other brands and idk what is common between them exactly.
What GlowShift product did you buy exactly, did it come with a controller?
They have instal instructions on their website for the instal of their wideband O2 w/controller. Glowshift wideband datalog
Here ya go!
http://www.glowshift.com/instruction...uel-Gauge-.pdf
As far as setting it up your wideband you can go into SManager and select the Closed loop tab and select wideband O2 input from the list. Then you choose the Closed loop advanced tab and select what ECU pin you want to use for wideband input.
This is all I needed info on.
parasonic
May 29, 2007 04:35 AM
