Manifold Gasket
Old Feb 9, 2015 | 04:58 PM
Rick1t's Avatar
Default Manifold Gasket
Hey Guys....just received my replacement Manifold, for my 1998 civic......360K and still great.....anyway the lower gasket i received is about a 3" circle........it looks like I need a gasket that has 3 stud holes with 2 smaller holes in it.........can you shed any light on this for me?
Thanks in advance
Rick
Old Feb 9, 2015 | 05:02 PM
slomofo's Avatar
GDD Member
Default Re: Manifold Gasket
Post pictures of it.
Usually the gasket is two rings (the two small circles) that fit into grooves in the manifold. If this is an aftermarket manifold, it may take a gasket that goes around the three studs.
Old Feb 9, 2015 | 05:03 PM
slomofo's Avatar
GDD Member
The two rings I'm referring to in this picture:
Old Feb 9, 2015 | 05:15 PM
Rick1t's Avatar
Thanks for the quick reply......the gasket that came with the Manifold is about 3" in Diameter. If I need 2 smaller one they would be about 1 1/2" in diameter. I've just now found some on ebay.........called "Exhaust Header Down Pipe Manifold Gasket" which I have not been able to find locally. Also found some nice chrome headers for less that i paid for the stock replacement one......but i dont want to redo the entire system........
I may need to just pull it apart and see if i need them? do you have any experience?
Old Feb 9, 2015 | 05:17 PM
slomofo's Avatar
GDD Member
The gaskets sit flat, almost flush with the flange. Can you snap a picture of it? There's a good chance the gaskets are actually in place, but you don't realize they're gaskets.
Old Feb 9, 2015 | 05:28 PM
Rick1t's Avatar
I haven't pulled it apart just yet. I will try to post a picture of what i think I need......
How do I post a picture?
Old Feb 9, 2015 | 05:30 PM
NotARaCist's Avatar
I never narc'd on nobody!
Wait, you haven't pulled it apart, you're just assuming it was assembled without a gasket in it? Huh?
Old Feb 9, 2015 | 05:35 PM
Rick1t's Avatar
So I haven't pulled it apart yet this is what I believe I need.....I was hoping you may have had your apart and could confirm.....
Old Feb 9, 2015 | 05:40 PM
NotARaCist's Avatar
Post a picture of the manifold you bought.
Old Feb 9, 2015 | 05:44 PM
Rick1t's Avatar
OK....so here is what I received in the new "kit"........I assume I need to find a new gasket? or do you think I can reuse the one I have?
turbotime
Dec 13, 2005 01:08 PM
the.hamburglar
Jun 29, 2005 11:50 PM
Paluce
May 26, 2005 09:58 AM
IntegraLova
Jan 13, 2004 01:19 PM
