Can't set TPS within spec
Old Feb 9, 2015 | 05:35 AM
RinzEG6's Avatar
Default Can't set TPS within spec
'02 DC5 type-R, stock TB. Just replaced the TPS for a bwr TPS because I couldnt get the TPS within spec.. nothing changed tho. If idle set at .48 the WOT is 4.90.. any ideas what can cause my TPS to be so far off? I'm not gonna mess with the throttle screw since that will open up the throttle plate too much.
Old Feb 11, 2015 | 03:00 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Default Re: Can't set TPS within spec
Sounds normal to me.
Old Feb 12, 2015 | 04:04 PM
Jnicks's Avatar
Should be 0.5v closed and 4.5v WOT
Old Feb 12, 2015 | 10:12 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
The numbers he posted are just fine and are with in spec.
Old Feb 13, 2015 | 12:35 AM
RinzEG6's Avatar
manual says it should be 4.5WOT. read at the forums that as long as it doesnt exceed 4.8WOT its fine..
Since I have some hessitation problems and rpm rises after coming to a stop with the clutch in I think its due the TPS not within spec.. I checked and cleanend IACV, replaced IM and TB gasket, checked for vacuum leaks..
Old Feb 13, 2015 | 02:06 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
As long as it doesnt reach 5v its fine. 4.90 is acceptable,if it weren't the PCM would code for high voltage. I'd start looking else where for your drivability problem.
Old Feb 14, 2015 | 01:22 AM
RinzEG6's Avatar
thanks! I've been told the TPS, MAP and IACV work together.. Could my problem have something to do with the MAP sensor maybe? I acctually have no idea what the MAP sensor is doing.. need to educate myself
Old Feb 14, 2015 | 08:33 AM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Honeslty with that car, it could be a hundred different things. Need to hook a scanner up to it and get some data to analyze, to lead you in a specific direction.....
Old Nov 22, 2015 | 11:25 AM
Nato18's Avatar
I have an 1995 accord and at CT it reads .70 volts and at WOT 4.5.. What could i do?
Apple395
Nov 23, 2015 02:26 PM
Shuggy
Honda Motorcycles
Sep 13, 2014 04:09 PM
o'malley_808
Aug 6, 2009 10:24 AM
salman
Sep 18, 2006 08:40 PM
CRX A4
Jun 14, 2003 09:43 AM
