CB600F4 TPS voltage settings
I am looking for the voltage settings for the TPS for a Honda Hornet CB600F4 (2004 model). I have the reference voltage but need the voltages for Throttle Closed and for Wide Open Throttle.
I knew I should have left it alone but I had an idle problem and moved it to see if it would help! Carbs are now balanced and it's running much smoother at idle.
Shuggy
Shuggy
Re: CB600F4 TPS voltage settings
Thanks slomofo. I set it to 0.48v closed so that should be about right. Can't believe the manual does not give this info!
djmota
06-15-2005 09:24 AM
