H22A1 oil pump the same as H22A4?
Old Nov 3, 2002 | 09:56 AM
Turbo Lude SH's Avatar
Default H22A1 oil pump the same as H22A4?
Basically I need to know if you can use a H22A4 oil pump on an H22A1 block?
I searched and didn't find much. Anyone know?
Old Nov 4, 2002 | 11:22 AM
flyrod's Avatar
Default Re: H22A1 oil pump the same as H22A4? (Turbo Lude SH)
The a4 pump has the crank sensor integrated into it. You can put it on an a1 block, but if you need the sensor, then you may need some other a4 parts as well.
Old Nov 4, 2002 | 11:30 AM
Default Re: H22A1 oil pump the same as H22A4? (flyrod)
So I can assume the crank sensor on the H22A1 is in the distributor like B series engines?
This would solve 2 of my problems if that is so.
schlong1
Oct 19, 2008 05:38 PM
nighttrain33
Oct 3, 2006 07:30 PM
existanzcivicb20
Mar 16, 2006 04:28 AM
warwagon
Jan 11, 2005 05:14 PM
ICeDoUt
Jan 10, 2005 09:50 AM
