2000 EM1 Ignition Issues
Old Feb 5, 2015 | 11:44 AM
StuG_Lyfe's Avatar
Default 2000 EM1 Ignition Issues
Long story short my SiR had a hiccup yesterday. Was pulling off the highway towards work when the CEL started flashing and the car lost most of it's power. I was close enough to work that I coasted it there and then shut it off. Car was struggling to idle and. Pulled the codes and it came up with a bunch of misfires (specifically P0301, P0302, P0304, P0300 and P1399. I'm pretty sure I've traced the problem back to the distributor, but I wanted to get a second opinion before I rushed out to buy one. Any thoughts?
Old Feb 5, 2015 | 12:06 PM
turbohatch96y7's Avatar
Are the plugs fouled?
Compression good?
Test the coil and icm in the distributor
Or like most of the people here just swap parts around
Old Feb 5, 2015 | 04:35 PM
joey1320's Avatar
Default Re: 2000 EM1 Ignition Issues
Did you check for proper spark?
Old Feb 6, 2015 | 07:23 AM
StuG_Lyfe's Avatar
The car is getting proper spark. I pulled all the plugs and only cylinders 1,2 and 4 have carbon build up. At this point I'm thinking it's the distributor
Old Feb 6, 2015 | 10:08 AM
MadVladCivic's Avatar
The car is getting proper spark? Would that not ELIMINATE the
dizzy?
If you are implying one cylinder is the culprit, that could be something
as simple as 1) a plug wire or 2) the corresponding contact on the
dizzy cap.
This reply assumes no mechanical issues, eg, head gasket etc.
Old Feb 6, 2015 | 10:23 AM
StuG_Lyfe's Avatar
I should have said that the plugs were new as of 10,000km ago. Compression is good. Spark is not. Having a bit of an off day
Old Feb 6, 2015 | 08:57 PM
Former User's Avatar
Open up the distributor and inspect.
How old are the plugs and wires?
Old Feb 7, 2015 | 08:50 AM
StuG_Lyfe's Avatar
Plugs and wires were replaced virtually right before I bought the car (so they're around 5 months old) I pulled the cap off the distributor. Had a lot of built up crap in there. Cleaned it out and it started running marginally better. Will be replacing the dizzy as soon as I can
Old Feb 7, 2015 | 09:20 AM
joey1320's Avatar
If the distributor was dirty and after cleaning it the engine runs smooth, then no need to replace the distributor.
Old Feb 7, 2015 | 11:52 AM
StuG_Lyfe's Avatar
It definitely doesn't run smooth. It's a tiny bit better than how it was running before I cleaned it out but it's still throwing the misfire codes
hondalord
May 27, 2010 08:42 PM
ILOVEGIRLS
Apr 19, 2006 07:52 PM
CptCorN
Jan 17, 2005 06:33 AM
KaRiZMa
Nov 7, 2004 03:30 AM
KaRiZMa
Nov 1, 2004 04:19 AM
