02 leaking PS pump cover
Old Feb 2, 2015 | 09:29 AM
mclasser's Avatar
Default 02 leaking PS pump cover
It's leaking exactly like in the picture below that I found online. I found a TSB for 5th gen Accords with this exact problem and the remedy was to replace the pump cover seal. The TSB calls for removing the pump off the car but is this necessary? Can't I just remove the 4 flange bolts and swap out the seal?
I also have a leak where the return hose meets the cooler line below the reservoir so I'm also going to take care of that. Interestingly, the pump isn't noisy and the fluid isn't foamy. I guess the pump hasn't started sucking in air...yet.
Old Feb 2, 2015 | 09:53 AM
holmesnmanny's Avatar
Obviously its going to leak and there should be springs. Its just easier to do it off the car but im sure it is possible.
Old Feb 2, 2015 | 04:48 PM
NerfGunner420's Avatar
Default Re: 02 leaking PS pump cover
**** no its not easy to do it on the car!!! no ******* way!!!!! better to do it on the table then open that up and have all the gears fall out and have no clue which way they go!!!. don't be lazy. 4 bolts total to remove. and one clamp on the hose
pityocamptes
Oct 23, 2013 07:29 AM
Prudz_lude
Jun 9, 2007 01:20 PM
darockstar
Apr 24, 2006 05:50 AM
morales232002
Nov 22, 2005 02:31 PM
I Like Boost
Aug 28, 2003 06:42 PM
