idle periodically surging up and down V6
Old Jan 29, 2015 | 08:35 AM
gimphand's Avatar
Default idle periodically surging up and down V6
I have a 2000 V6 accord cpe with 110k. this first happened about 500 miles ago when I was parked in a traffic jam after about an hour. The check engine came on but I though it may have been from sucking in all the exhaust from the rigs..... havent got the code read yet.. Once I opened it up on the highway everything ran fine... Then about 500 miles later, i started it up and the idle was bouncing again from 500 to 2000. It even would go up in drive when the idle got low coasting. After about 4 miles, I floored it and took the rpms up to about 5-6K and its been fine for the last 20 miles... both times this happened I was facing downward on a slight slope.. any thoughts other than cleaning/replacing IAC valve.. Im going to try that first when I get a minute..
Old Jan 30, 2015 | 12:22 AM
slowcivic2k's Avatar
Default Re: idle periodically surging up and down V6
You need the code that was produced. A drop in idle speed in a V67 can be attributed to a misfire as well, among other things. Even if the light is not on, provided you have not stupidly disconnected the battery, the code will still be there. Given your limited information it is very hard to help you. You need to tell us more information, like when the problem started, and the last repairs done to the car within the last 6 months etc.
Old Jan 30, 2015 | 05:53 AM
gimphand's Avatar
This only happened twice. First time was about 500 miles ago, second time was about 30 miles ago. No work done recently. 1 Coil, timing, and water pump changed about 1-1.5yrs ago.... the check engine light has been on since the first incident but went out today..
Old Jan 31, 2015 | 06:49 AM
Lost Again's Avatar
The code is still there, get a scanner and get it.
By chance does this seem to happen when re-starting a warm engine - car is at normal op temp, shut it off to do something, 10~20 minutes later you start it up and the "issue" happens?
The code and details will help.
Old Feb 2, 2015 | 07:38 AM
gimphand's Avatar
no
first time, I was in a traffic jam in park running for 1.5 hours and it started, second time was starting it up on a 20 degree morning...
Old Feb 2, 2015 | 04:36 PM
Lost Again's Avatar
Ok, get the code then
At the same time we now have more details to work with/from
Jack jaxz
Engine Management and Tuning
Mar 22, 2016 04:29 AM
premo_si
Aug 29, 2006 07:33 PM
c0nspire
Feb 23, 2006 02:09 PM
russian_racer
Jun 28, 2003 02:01 PM
Ham'ed Hatch
Dec 15, 2002 09:21 AM
