Crack in valve cover
Old Jan 28, 2015 | 02:45 PM
therhett17's Avatar
Default Crack in valve cover
I noticed today that there is a small, about 1 1/2 inch long crack on the valve cover of my 1997 Accord LX, as seen in the attached pic. It's leaking a little oil down the backside of the cover and spraying a little on the underside of the hood. I'd really like to fix it, so what's a good way (if there is a way) to patch the crack? Thanks!
Old Jan 28, 2015 | 03:43 PM
NerfGunner420's Avatar
Default Re: Crack in valve cover
jb weld. or or take it to a shop have them weld it shut and sand it down to the curve again
Old Jan 28, 2015 | 04:32 PM
Lost Again's Avatar
I'll guess you cleaned the area up.
That crack, that high up.....is not the source of a leak IMHO. A dab of silicone on your finger across that and done.
Now I have to ask how or "why" that is there.
Don't get me wrong - I would patch it until I could stop by a bone yard and grab another but based upon your description of the "leak".....that is not the source.
Old Jan 28, 2015 | 04:38 PM
lostforawhile's Avatar
longest project ever
From: on the south side of dixie, 1986 Accord Hatch
there is no pressure inside of the valve cover, so it wouldn't be spraying oil under the hood, you have a leak somewhere that is under pressure
Old Jan 29, 2015 | 08:23 AM
holmesnmanny's Avatar
Just put some rtv on that crack and let it cure(dry) for about two hours.
Old Jan 29, 2015 | 01:50 PM
94 accord typeR's Avatar
or u could get a new valve cover
Old Jan 29, 2015 | 05:14 PM
this is a temporary fix until he gets his repaired I think
Old Jan 29, 2015 | 06:14 PM
viper_boy403's Avatar
lol ok. Go take your oil cap off with the engine running and tell me oil doesnt come blasting out. Especially on an F series, they'll have a decent amount of blowby at this day in age. The stock PCV system is relatively inadequate and doesn't zero out crankcase pressure. It may not actually "spray" out of this crack, but I guarantee it's leaking pretty good, well enough to get on the underside of the hood
Throw a new valve cover on that thing and be done with it
Old Jan 29, 2015 | 07:21 PM
Yeah, there isn't really a whole lot of pressure up top but there definitely is pressure and oil is slinging all over up there. If you just start the car up and take off the oil filler cap you will see what kind of pressure there is.
sh!ft
Welding / Fabrication
Aug 12, 2010 01:06 PM
Rikaro
Mar 11, 2009 01:25 AM
aleks77
Jul 11, 2007 04:49 AM
