wont start!!!!
Old Jan 24, 2015 | 04:53 PM
muddywj's Avatar
Default wont start!!!!
Went to do a simple tune up on my 97 hx non vtec and after it started then died after running for 30 seconds. I changed cap,rotor,plugs,wires and fuel filter. In the process changed out the efi main relay,icm and replaced pump fuses. It currently gets No spark. No CEL is thrown. Any guidance is appreciated.
Old Jan 24, 2015 | 04:57 PM
grumblemarc's Avatar
The Grumpiest
Default Re: wont start!!!!
Why? If there was nothing wrong with these try swapping for the originals.
Old Jan 24, 2015 | 05:06 PM
muddywj's Avatar
I searched the issue and those were suggested.
Old Jan 24, 2015 | 05:46 PM
White_EG1's Avatar
Bench test your ignition coil.
Old Jan 24, 2015 | 05:52 PM
ek9_beast's Avatar
Or swap back icm
Old Jan 24, 2015 | 06:29 PM
muddywj's Avatar
Just went to parts store for a new coil. They had one! If that doesn't work I'll switch the ICM back. My buddy owns a shop and said he would help but I'd like to solve this myself.
Old Jan 24, 2015 | 06:37 PM
Former User's Avatar
Check whether the fuel pump primes.
Old Jan 24, 2015 | 06:48 PM
muddywj's Avatar
Pump primes. Changed fuel filter during tune up. Cracked the top bolt and got gas as well as unscrewed the gas cap and there was pressure built up. I can hear it prime too.
Old Jan 24, 2015 | 10:14 PM
muddywj's Avatar
Got it all sorted out. Bad coil! Bright side is a freshly rebuilt distributor. On to the steering/suspension.
Old Jan 25, 2015 | 04:12 PM
EkkS's Avatar
Good luck on the rest!
smileygreasy
15
Apr 19, 2015 07:36 PM
roc0487
May 26, 2012 03:45 PM
djw19842005
Sep 9, 2009 10:45 PM
WanaBeFaster
Nov 13, 2007 06:32 AM
torzy
May 9, 2006 02:14 AM
