91 Honda Accord(No Spark!)
Old Jan 18, 2015 | 03:04 PM
reginold_2006's Avatar
Icon2 91 Honda Accord(No Spark!)
Hey guys I have searched the internet for quite a while now including this site. My 91 Accord has no spark! It turns over just fine and has no fire to plugs. I have changed the entire Distributor(Including all parts, Coil, Rotor Button, Igniter, Cap), new Plugs and Wires, New Main Relay! Still nothing really need help don't want to sell it for parts but looking like no other choice! Thank you!
Old Jan 18, 2015 | 04:09 PM
holmesnmanny's Avatar
Check all of your fuses with a multimeter, the engine bay and the driver side kickboard.
Old Jan 18, 2015 | 06:39 PM
Default Re: 91 Honda Accord(No Spark!)
Thanks for the reply but i covered that too.
Old Jan 19, 2015 | 03:55 AM
NWsleeperswaps's Avatar
when you turn the ignition to the "on" position do you hear a click as well as the cel (check engine light) turn on followed by a faint humming of the fuel pump priming in the rear seats then both the cel light and fuel pump turn off with a click? if that process does not happen then your main relay is not functioning correctly. treat this by first slamming your door or wiggling it around as the solder in the connections breaks. if that doesnt work either resolder the pins on your main relay or simply replace it.
Old Jan 19, 2015 | 03:59 AM
i just now saw you said it has a new main relay. have you played with your ground connection under your thermostat housing yet? that is the ground your ecu uses for the cps signal that tells your ignitor to send a signal. make sure its clean and free of corrosion.
Old Jan 19, 2015 | 04:01 AM
also bad battery connections or corrosion in the wires can cause simmilar problems.
Old Jan 19, 2015 | 04:06 AM
i have litterally the same problem as you and ive pretty much nailed it down to a bad ground i got the new dizzy and all components in, main relay is good, have power to the dizzy, but no spark. ill keep you posted with my findings and i tinker with it today. mines a 90 5speed w/ p/w, p/s, a/c, and a sunroof.
Old Jan 19, 2015 | 12:01 PM
Hey thanks for the reply's but yeah I have thought of those as well took off the ground under the thermostat and cleaned it and replaced the battery terminals with new ones and put in a battery that in know is good the clicks are there as well as the fuel pump and the CEL comes on and then goes off after a couple of seconds like it should I'm still stumped not sure but think maybe the MAP sensor is bad not allowing the ECU to send signal to the Distributor but its REALLY expensive and want to be 100% sure that is the cause before replacing it!
Old Jan 19, 2015 | 12:07 PM
the map sensor should not affect the ignition at all in any way during starting. before you go off buying more parts unplug your coolant temp sensor and try starting it. if that sensor has failed your ecu will not send any signal to the ignitor. the car will run with it unplugged. give it a try.
Old Jan 19, 2015 | 02:02 PM
Status update.
Cleaned the ground. Then threw code 3 for map sensor. Redid vacuum lines to it and code went away then threw 8 for Tdc sensor going to replace that now. Let you know what happens
Old Jan 19, 2015 | 04:21 PM
Ok thanks for the update!
Old Jan 19, 2015 | 06:22 PM
After I installed the cps it fired right up!
Old Jan 20, 2015 | 02:29 AM
Isnt the cps in the Dizzy?
Old Jan 20, 2015 | 08:35 PM
Yes it it's. Specifically it was the Tdc sensor. Cel code 8
Twisted sid
Mar 27, 2017 12:47 PM
91legend
41
Nov 5, 2012 09:48 AM
pmey
May 26, 2009 01:11 PM
SLOSI7
Jun 19, 2008 06:31 PM
xelf
Jan 21, 2005 06:56 AM
