► Omnipower Tachometers! - Replace your old inaccurate tach! ◄
Old Jan 15, 2015 | 11:58 AM
mtber's Avatar
Icon7 ► Omnipower Tachometers! - Replace your old inaccurate tach! ◄
- Omni Power Tachometer 92-95 Honda Civic EG - $139 - CLICK HERE TO ORDER!
- Omni Power Tachometer 96-00 Honda Civic EK - $149 - CLICK HERE TO ORDER!
- Omni Power Tachometer 90-91 Honda EF - $149 - CLICK HERE TO ORDER!
New from Omni Power!
*EG Tachometer does not have a shiftlight option.
*EK Tachometer features a user programmable shiftlight
*EF Tachometer features a user programmable shiftlight
Omni Power replacement tachometers are unique because they fit directly into the factory cluster and require no wiring or custom mounting. This feature allows the vehicle to retain a factory look, with a more accurate and higher RPM capability.
Omni Power developed their own software in house to run the modern digital gear driven stepper motor. This was crucial to ensure that the tachometer is accurate and has fast enough movement to keep up with highly responsive high revving engines. Omni Power uses the same digital gear driven stepper motor as Porsche and other exotic automobiles use.
The OEM Honda EF, EG, EK and DC tachometer is not accurate. Typically they read about 200-600 RPM fast at engine speeds above 7000 RPM. Omni Power developed a special monitoring software that ensures that their tachometer will be incredibly accurate at all RPM speeds. Each tachometer is manufactured in the USA. Assembly, programming and testing are done in house, to ensure the highest level of quality.
THE CLUSTER IS NOT INCLUDED WITH YOUR PURCHASE. TACHOMETER ONLY
Old Feb 3, 2015 | 05:39 AM
mtber's Avatar
Default Re: ► Omnipower Tachometers! - Replace your old inaccurate tach! ◄
ttt t
Old Feb 21, 2015 | 03:06 AM
dsmarefaster's Avatar
bump
Old Feb 21, 2015 | 05:48 AM
mtber's Avatar
Originally Posted by dsmarefaster
bump
Thanks
Old Feb 21, 2015 | 08:56 PM
JustOneOrTwoPosts's Avatar
sounds cool. Any actual pictures of the EF ones installed and operating? Also, there is no other info about the programmable shift light on their website. Do you have any info about it?
Old Feb 24, 2015 | 06:28 AM
mtber's Avatar
Call omni power to have them email you pictures & instructions or ask about the specific questions you have.
Their phone number is on their website Contact Us | omnipowerusa.com
stdefhatch
Jul 2, 2015 04:47 PM
stdefhatch
Jul 2, 2015 04:42 PM
jklogan18
Dec 7, 2013 04:40 AM
shifflett_ben
May 10, 2011 06:18 PM
91hondacrx
Nov 26, 2003 09:34 PM
