► Omnipower Tachometers! - Replace your old inaccurate tach! ◄
http://phearable.net/images/tachshowcase.jpg
http://phearable.net/images/efomnishowcase.jpg - Omni Power Tachometer 92-95 Honda Civic EG - $139 - CLICK HERE TO ORDER! - Omni Power Tachometer 96-00 Honda Civic EK - $149 - CLICK HERE TO ORDER! - Omni Power Tachometer 90-91 Honda EF - $149 - CLICK HERE TO ORDER! New from Omni Power! *EG Tachometer does not have a shiftlight option. *EK Tachometer features a user programmable shiftlight *EF Tachometer features a user programmable shiftlight Omni Power replacement tachometers are unique because they fit directly into the factory cluster and require no wiring or custom mounting. This feature allows the vehicle to retain a factory look, with a more accurate and higher RPM capability. Omni Power developed their own software in house to run the modern digital gear driven stepper motor. This was crucial to ensure that the tachometer is accurate and has fast enough movement to keep up with highly responsive high revving engines. Omni Power uses the same digital gear driven stepper motor as Porsche and other exotic automobiles use. The OEM Honda EF, EG, EK and DC tachometer is not accurate. Typically they read about 200-600 RPM fast at engine speeds above 7000 RPM. Omni Power developed a special monitoring software that ensures that their tachometer will be incredibly accurate at all RPM speeds. Each tachometer is manufactured in the USA. Assembly, programming and testing are done in house, to ensure the highest level of quality. THE CLUSTER IS NOT INCLUDED WITH YOUR PURCHASE. TACHOMETER ONLY |
Re: ► Omnipower Tachometers! - Replace your old inaccurate tach! ◄
ttt t
bump
Originally Posted by dsmarefaster
(Post 50220065)
bump
sounds cool. Any actual pictures of the EF ones installed and operating? Also, there is no other info about the programmable shift light on their website. Do you have any info about it?
Originally Posted by JustOneOrTwoPosts
(Post 50221155)
Their phone number is on their website Contact Us | omnipowerusa.com |
