B20b4 with 270k on it
Old Jan 11, 2015 | 10:15 PM
Tocco215's Avatar
Default B20b4 with 270k on it
Hi guy, I need some opinions. I bought a b20b4 from a buddy, has 270k on it and it ran great when he pulled it out of his crv. I tore it apart, cams have no scarring on them, top end looks perfect. I'm putting a new oil pump, water pump, timing belt, and head gasket on it.
My question is, should I rebuild the bottom end of the motor? It ran good when pulled, cylinder walls look perfect, just don't know if I should rebuild it or not, money is tight so if I dont have to I don't want to.
Also, how should I inspect the crank bearings and all the other stuff down there? Thanks guys
Old Jan 13, 2015 | 08:37 AM
Dark_Teg's Avatar
Default Re: B20b4 with 270k on it
Should have done a leak down test while the engine was together and you would have your answer. For me 270K would equal automatic full rebuild.
Old Jan 13, 2015 | 08:48 AM
ChrisCoupe1's Avatar
It cant hurt and would probably be for the best to go ahead and re-ring it along with a full set of new gaskets and seals top and bottom, new bearings depend on how worn they are which would mean measuring with plasti gauge. just comes down to how thorough you want to be,a solid $300 or so now on new seals and bearing would probably give you another 200,000+
Old Jan 13, 2015 | 05:27 PM
blackeg's Avatar
i would rip it apart for a full rebuild as well unless you need it for a short time as a beat around not to really be romped on.
personal story - i got a b18b from my friends wifes teg that got rear ended. it was always maintained and she never revved it out. i think it had around 220-230k miles on it and it didnt really smoke but would loose a bit of oil and coolant every oil change. i took it apart to use the block in a boost motor and i found it had a hairline crack in a sleeve. totally worthless even though it ran reasonably well and didnt have a smoke cloud following it around. compression was 175-185 psi if i remember correctly too
Old Jan 13, 2015 | 06:42 PM
B20VtecVillain's Avatar
Agree with everyone else here; it's already out and torn down so you might as well spend a few hundred bucks and know your good for another couple hundred thou on the odometer.
Old Jan 19, 2015 | 06:59 PM
Tocco215's Avatar
Thanks guys, and I did decide on going with a full rebuild. Getting new pistons, rings, headgasket, arp headstuds, arp rod bolts, acl crank bearings. Also having my rods shotpeend
TooManyTickets
14
May 27, 2007 03:05 PM
Under Con. CrX
Apr 22, 2007 08:27 AM
B18C_EJ8
Oct 31, 2004 10:15 AM
pnthr30
Oct 31, 2003 07:29 AM
Gir
26
Jun 16, 2003 06:09 AM
