97 civic d16y7 - Replacing bearings in transmission
Old Jan 11, 2015 | 12:10 AM
lalib's Avatar
Default 97 civic d16y7 - Replacing bearings in transmission
Hey guys I'm trying to replace some noisy bearings in my transmission. I've already got it all apart and took out the old input shaft bearing. However I noticed that another bearing was destroyed. I believe this is the mainshaft bearing? The outer race seems to be stuck in the case. Was this bearing supposed to come out attached to the whole gear set like it is in this first picture? Anyone know what part # this is? Also what is the plastic beneath it? Mine is broken. Do I need it? The last three pictures are mine.
Old Jan 11, 2015 | 06:24 AM
grumblemarc's Avatar
The Grumpiest
Default re: 97 civic d16y7 - Replacing bearings in transmission
Do yourself a favor and Google for, and download, the Factory Service Manual.
Old Jan 11, 2015 | 07:27 AM
92ehatch's Avatar
What transmission is that? You failed to mention anything about it
Is that not the main shaft bearing?
A bearing puller should get the race out
Old Jan 11, 2015 | 08:22 AM
lalib's Avatar
sorry i forgot to mention this is off a 97 civic d16y7
Old Jan 11, 2015 | 09:52 AM
tamboo's Avatar
10 Year Member
sent you pm with link to manual.
Old Jan 11, 2015 | 12:10 PM
92ehatch's Avatar
Honda Automotive Parts
I think 13 is what you need.
Should pull race out and press new bearing in
Old Jan 11, 2015 | 03:57 PM
lalib's Avatar
thanks for the manual tamboo!
92ehatch, are you certain the new bearing gets pressed into the transmission case? because every time I watch any videos or see pictures, the bearing is attached to the gear set..as shown in the first picture.
Old Jan 11, 2015 | 04:06 PM
92ehatch's Avatar
I do not know for sure, i have never taken one apart.
I can tell you that bearings work by running the inner race against the ***** and the outer race staying stationary. I would then assume is pressed
Old Jan 11, 2015 | 06:05 PM
CX-Adam's Avatar
talks to himself
Community Builder
Community Influencer
It does NOT get pressed into the case. The only bearings that are pressed into the case are on the clutch house side (actually they're taped in with a hammer). There are no bearings pressed into the bellhouse side.
Old Jan 11, 2015 | 06:06 PM
CX-Adam's Avatar
talks to himself
Community Builder
It's pretty clear in the FSM that the bearing needs to be on the mainshaft.
Old Jan 11, 2015 | 06:13 PM
rockycat's Avatar
Could be wrong but the bearing looks very bad. Look at the housing and make sure the outer race did not spin.
Old Jan 12, 2015 | 11:07 AM
lalib's Avatar
Default Re: 97 civic d16y7 - Replacing bearings in transmission
does anyone know where I can find that plastic piece that goes behind the bearing in the transmission case?
Old Jan 13, 2015 | 05:43 AM
CX-Adam's Avatar
talks to himself
Community Builder
Majestic Honda - The Internet's #1 Honda Automotive Parts Store
You're probably better off figuring out what the part number is and then going to a stealership.
parahelium
Transmission & Drivetrain
Jun 8, 2017 10:46 AM
Hellahflush
Mar 27, 2015 05:15 PM
TravisBiggie
Honda Civic (2001 - 2005)
Nov 25, 2012 02:00 PM
LsTurbo91
Jul 16, 2002 08:00 PM
