need help with d series swap
Old Jan 9, 2015 | 05:16 PM
2816911965's Avatar
Default need help with d series swap
Hello I have a ek, I had a d16y7 non vtec but I decide to swap it for a d16y8 vtec, I intall the d16y8 with all the harness and computer, now my car won't start, I have spark but no fuel, I have no power to fuel pump, what can I do?
Old Jan 9, 2015 | 05:31 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: need help with d series swap
Year make model? What year is the engine and harness? Check engine lights on?
Old Jan 9, 2015 | 07:03 PM
2816911965's Avatar
Car is 2000, and engine I think 97, the d16y8 came with harness and ecu so I thought it would be a plug and play but no
Old Jan 10, 2015 | 03:41 AM
Technical Hero
You can't use that harness or any other 96-98 as they have different ECU connectors, you must either use your factory harness and add the additional wiring (VTEC, knock, 3-2 wire IACV, extend secondary 02 and use your original distributor for plug and play or an distributor adapter harness) or you can use a 99-00 EX harness and then wire in the secondary 02 manually to the ECU and reuse your original distributor as the plugs differ.
Old Jan 10, 2015 | 06:35 AM
2816911965's Avatar
So I can't use the harness and ecu that came with the engine?
Old Jan 10, 2015 | 07:18 AM
Technical Hero
Not unless you get a 96-98 dash harness as well.
HotrodHooptie
Jan 6, 2018 02:59 AM
Jvelez1216
Mar 14, 2016 08:51 PM
8 valves of fury
Jan 17, 2008 03:18 PM
goat442003
Jun 21, 2003 07:16 PM
length
Jun 10, 2003 11:57 AM
