Difference from a B16 and a B18 tranny.
Old Jan 6, 2015 | 06:22 PM
EG95PR's Avatar
Post Difference from a B16 and a B18 tranny.
Good evening, how do I know the difference between a B16 or B18 tranny. A buddy of mine told me that the B16 should have a green plate in front of the tranny, but if I don't have that plate the other way to find out will be to cruise on 5th gear around 40 - 45mph and check the rpm. If the rpm stays around 2000 or 2300 I have a B16 tranny. How true is that? Thanks.
Old Jan 6, 2015 | 07:24 PM
93egSLEEPER's Avatar
Default Re: Difference from a B16 and a B18 tranny.
Are we talking B18 LS, GSR or ITR tranny? All three will be different.
Old Jan 6, 2015 | 08:13 PM
Mccormick009's Avatar
Are any of the markings or printed numbers still visible on the tranny?
Old Jan 7, 2015 | 04:53 AM
EG95PR's Avatar
Damn, I aint go no idea. The engine is an LS, other than that I don't know. Sorry. Well I find this code in the tranny don't know if it could be of any help. Y80-1036208.
Old Jan 7, 2015 | 06:14 AM
Easiest way to start is by counting teeth on the final drive. Since it is mated to and LS motor I would be willing to bet it is an LS tranny.
I like to confirm trannys by counting teeth. people can swap cases. My buddy had an LS tranny in an ITR case (the LS case was cracked and he found an ITR case on EBAY)
Old Jan 7, 2015 | 08:09 AM
EG95PR's Avatar
Ok, man thanks, for the info. I will do that.
Old Jan 7, 2015 | 10:49 AM
93ericSi's Avatar
http://www.ff-squad.com/tech/temp/Bgears.htm
Here's some help when you do the count.
88 EF Hatch
Transmission & Drivetrain
Aug 1, 2009 10:28 AM
lmananT
Apr 21, 2006 11:21 AM
a2dadamm
Dec 29, 2005 01:24 PM
EFM_ookie
Jun 2, 2005 06:10 PM
jarvis199
May 7, 2005 07:51 AM
