99 Civic DX Auto Spins but slow does not start
Old Dec 31, 2014 | 11:45 AM
f575gtc's Avatar
Default 99 Civic DX Auto Spins but slow does not start
Hey guys, I need some help
I bought a 99 DX Automatic and the engine is having some problems. It will turn over but while it is turning over it makes a high pitched screeching, and it feels like the engine is spinning very slow. It almost feels like something is binding. The screeching is coming from the starter/ transmission side.
I tried the starter off my known working 2000 civic and it makes the same noise, so it is not the starter, I even tried a new battery with proper amps and it has the same symptoms. I also measured the voltage while cranking it is at a reasonable number.
I took all the plugs off to remove all compression, same issue. I tested all pistons are moving up and down, the timing belt is intact. I can spin the engine by hand with a ratchet on the crank pulley, I haven't taken the accessory belts off, but the engine spins without much effort.
I am running out of ideas. The transmission rolled freely when it was in gear so I don't think it is anything in the transmission binding.
Any ideas? Can something have seized like a bearing that will put too much force on the starter? I figured if there is too much resistance on the starter I should feel it by hand.
Thanks
Old Dec 31, 2014 | 11:53 AM
Former User's Avatar
Default Re: 99 Civic DX Auto Spins but slow does not start
Try cleaning and tightening the G1 battery and G3 transmission ground connections.
Old Dec 31, 2014 | 03:14 PM
f575gtc's Avatar
Found the issue.
I thought I had loosened the alternator completely but I did not, I took the alternator belt off and the engine spins freely now, the alternator is completely seized.
Problem now is I am getting no spark.
I checked all the grounds, I pulled the distributor and checked the ignition coil, all the ohms read within spec.
I am not getting spark on any cylinder. I do get fuel and the pump is priming.
Old Jan 1, 2015 | 04:09 AM
ek9_beast's Avatar
Do u have power to the coil?
Old Jan 1, 2015 | 06:32 AM
f575gtc's Avatar
nope, I am slowly tracing everything back.
Old Jan 1, 2015 | 06:38 AM
ek9_beast's Avatar
Generally if you dont have power to the coil its a Bad ignition switch.. U say its turning over tho correct? Does the main relay "click" when u turn the key over?
Old Jan 1, 2015 | 07:18 AM
Check fuse 9.
Old Jan 1, 2015 | 07:52 AM
f575gtc's Avatar
So I have power at the ignition coil/distributor plug I also have an ignition signal.
Could it be a bad ignition coil?
Fuses were all checked and are good
Checked the main relay its sending a signal, its getting an ignition signal at the key.
It seems to be an issue in the distributor.
Old Jan 1, 2015 | 07:55 AM
Does the fuel pump prime?
Any CEL codes?
Old Jan 1, 2015 | 08:18 AM
f575gtc's Avatar
So I am getting a signal from the ECM for ignition, but no signal out to the ignition coil, according to troubleshoot my car it is the ignition control module.
Old Jan 1, 2015 | 08:31 AM
ek9_beast's Avatar
Yep, u have it narrowed Down to the icm since the coil checks out
Old Jan 1, 2015 | 08:26 PM
f575gtc's Avatar
Car is running!
Ended up being the ignition coil, I tested it incorrectly the first time there was a signal coming from the ICM, I took a known working ignition coil and the car fired right up.
Thanks for the help.
Gwells
Oct 30, 2017 04:12 PM
Zencer
14
Mar 29, 2015 07:10 AM
JdmCrx209
27
Apr 30, 2013 08:49 AM
cs451
Oct 18, 2011 06:33 PM
fe519
Feb 22, 2004 09:23 PM
