99 Civic won't crank
I have been reading various threads re: no start
Its a 1999 Civic DX, starter clicks once when key is turned, does not turn over. Dash lights stay on the entire time, headlights dim but only very slightly.
Battery reads 12.6 V. Tried tapping the starter to no avail. Push starts just fine. Where do I go next?
I like the tuna here
re: 99 Civic won't crank
Make sure the one spade connector that goes to the starter solenoid is firmly attached, if it's loose it will not start even when tapping the starter.
Re: 99 Civic won't crank
Did you ever figure this out? mine just started this today, was driving it at lunch , then 3 hrs later , it won’t start. same description as yours just a 02 Civic EX Automatic
could be time for a solenoid rebuild kit. inspect your contacts.
How to: rebuild your honda starter - Carolina Hondas
https://www.ebay.com/itm/DENSO-START...9Z2CQo&vxp=mtr
allsho
08-05-2008 04:30 PM
