Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
2001 Civic idles rough
Old Dec 30, 2014 | 04:15 PM
swirly's Avatar
Default 2001 Civic idles rough
My 2001 civic idles rough and sometime will almost stall. Off idle it seams to be running fine. All I have looked at is the spark plugs and air filter and both are good. Someone I spoke to said this is normal on these cars but I don't buy that. Anyone with ideas on this?
Old Jan 7, 2015 | 02:17 PM
laudarch's Avatar
Default Re: 2001 Civic idles rough
Start the car in neutral and rev the engine to 3000rpm maintain it there for 5mins and that should solve your problem, btw this is my way of doing it but the service manual says you rev at 3000rpm in neutral till the fan comes on then let the engine idle for 5 minutes. You should do this anytime you disconnect the battery or reset the ECU. Hope this helps
fessup
Honda CR-V & Element
Dec 7, 2017 01:11 PM
raymondpowens
Aug 22, 2014 05:12 PM
jaycapz
Sep 1, 2004 02:43 PM
hahnchen
Mar 11, 2004 04:13 AM
Type R 702
Mar 4, 2002 02:50 PM
