f22 to f23
They are two different styles of actuating motor. You would be better off making/buying a 3 to 2 wire IAC adapter plate. There are a few F23 swap builds that cover this. Hopefully one of the contributors will chime in with more details.
Google Black Trax IAC Adapter. Or 3 to 2 wire IAC conversion.
I used the Rosko Racing adapter. All the adapters are 1/2" thick and you'll have interference with the TPS. Three( four really, if you feel inclined to delete the IACV) options:
1. Cut down one of the barbs coming off the IACV so clearance is not an issue. This is what I ended up doing.
2. Buy a throttle body spacer.
3. Make your own iacv adapter, at least 1" thick.
giddyup21
Mar 18, 2012 06:49 PM
