95 Civic losing coolant
Old Dec 28, 2014 | 03:29 PM
tercelrcr's Avatar
Default 95 Civic losing coolant
Hey HT so I just recently purchased a new 95 civic with d16z6. The car runs great except for it is loosing coolant somewhere. There is no water in oil and no white smoke so I doubt it is the head gasket. The car does not over heat at all, and there are no visible leaks except for a small amount around the top of the overflow bottle. The overflow fills up then it spits a little out around the top opening. I replaced the hose and put hose clamps thinking it was a bad hose. Still having the same issues. It almost seems as if there is too much pressure in the cooling system causing it to open the radiator cap and fill the resivor. And ideas
Old Dec 28, 2014 | 04:00 PM
92ehatch's Avatar
Default re: 95 Civic losing coolant
Try a new radiator cap. The lack of pressure can cause them to bubble out. The idea behind the cap is to hold pressure which raises the boiling point.
If that fails you probably have a bad head gasket and or stuck thermostat
Old Dec 28, 2014 | 06:24 PM
Former User's Avatar
Rent AutoZone's block tester kit.
Old Dec 30, 2014 | 02:31 PM
Originally Posted by slomofo
See if autozone can sell you some tightening coolant to counteract the coolant that is loosening. Maybe it will even things out?
^May fly over OP's head.
Old Dec 30, 2014 | 03:19 PM
crazyhouse2011's Avatar
Default Re: loosing coolant
op do this. if everything is fine i would STRONGLY suggest flushing out your cooling system. And get a new thermostat as well. Simple job. even a dumb *** like me could do it, and i've done it to other vehicles (not always hondas) since. If you use water to flush it out (reccommended), make sure to use ONLY distilled. Not purified, not tap water, not garden hose water. DISTILLED.
Mhillips
Jul 31, 2013 07:16 PM
harrashn
Feb 28, 2012 01:30 AM
MountainMan
12
Jul 12, 2011 04:42 AM
j-harts4
Honda Civic (2001 - 2005)
Jun 15, 2009 07:15 PM
tigueremalo
Jul 10, 2006 07:16 PM
