good news - paint is polished, bumpers polished - came up quite nice
bad news - checked brake master cylinder and it's empty, will check rear wheel cylinder for leaks, front calipers for leaks and then put a new seal kit through the master cylinder
does it have S800 brakes? iv'e managed to mock up Renault 5 Turbo discs and a modern Wilwood caliper to fit under the 13 inch wheels
not yet finalised but i can't see any issues.
great thing is these Wilwoods are very cheap and the discs are very easy to get hold of. disc will need a tiny amount of machining and i have a drawing of a caliper mount i can pm you if you want to go in this direction?
Any chance you'd be interested in selling a complete solution (disk, caliper, and mount combination), or perhaps just your mounts with part numbers for disks and calipers?
If there's anything my S800 needs, it is some decent brakes. Chasing faster cars through some touge works really well until I start to get some serious & rapid fade. The original RSC racing disks are expensive, hard to find in reasonable condition, and most importantly nowhere near as effective as I would guess your combo is.
Interested in your fluid volume calculations as well, any idea if master cylinder stroke & diameter are sufficient to support the four piston Wilwoods? Neko.
Keen to understand more on the brake setup, one thing we find with the 800's is they run out of brakes by the bottom of the range (128 corners) and would like to investigate updating our too.
