h2b swap help in my crx!!!!!!!
Old Dec 24, 2014 | 11:03 AM
JDM_home's Avatar
Default h2b swap help in my crx!!!!!!!
Ok well here is my only problem and im sure that some people has seen this common problem. I have a qsd kit, which sits the motor a little higher then most kit and also a lower qsd alternative (alternator) which sets the alternator low on the block problem is i cant figure out what traction bar to get fit anypone has one fs or know which right one to get plz tell me
Old Dec 24, 2014 | 03:31 PM
Bently_Coop's Avatar
Steve at Heart
I have the innovative traction bar. It is actually the cheapest and from what I have read its the only correct one with the way the radius rods are setup. Others have heims at both ends and allow the LCA's to rotate. Also Whitfield company/Rage induction has spacers available to lower it on there website which may help.
Do you have a build thread? Check out the H2B discussion in the hybrid section also. Also check out the link below.
Originally Posted by kingofbattle909
JDM_home
Apr 9, 2015 07:09 PM
JDM_home
Jan 19, 2015 06:43 AM
h22nick
Aug 20, 2009 11:26 AM
