2000 civic si cooling system problem... Help!!
Old Dec 22, 2014 | 10:42 AM
skyliner34life's Avatar
Icon2 2000 civic si cooling system problem... Help!!
Hello my name is Jordan, I own a 2000 Honda civic si and the car has been recently running hot. Although the car has not overheated the car ran hot the first time because of a leak which I fixed. the car is now running hot again and me and my brother have noticed the cooling fan isn't kicking in when it should. so I alligator clipped the fan to the battery and it runs as it should, I rreplaced the cooling fan switch on the thermostat, the relay is fine, the fuse is not blown. Yet the fan has still not kicked on when its at operating temperature and the car will result in running hot. I took my car to my local shop and he said that he thinks the head gasket is bad? if the headgasket is bad why would my fan still not kick on??? also my car has no oil in the antifreeze and it does not seem to blow white smoke , also has no antifreeze and I am not losing antifreeze. if my headgasket is bad that is fixable but I was curious does anyone know whats wrong with this fan situation??? it seems like something is not telling it to kick on.... please help!!!!!! Ps: Also I think there is air in the system which I will bleed because I hear bubbling under the dash and Im almost positive the radiator is working because it doesn't usually run hot immediately
Old Dec 22, 2014 | 12:37 PM
axis11's Avatar
Default Re: 2000 civic si cooling system problem... Help!!
Bleed the cooling system.
Unplug thermoswitch connector and use a wire to short the connector(wire side).
Old Dec 22, 2014 | 12:49 PM
Short the connector? Like jump the 2 wires on the plug to the cooling fan switch?
Old Dec 23, 2014 | 12:49 AM
axis11's Avatar
Yes, short the terminals for the fan switch.
If the fan turns on, the electrical circuit is fine.
Bleed the system of air. Trapped bubbles prevents the thermostat and/or thermoswitch to work properly.
Old Dec 23, 2014 | 03:15 AM
92ehatch's Avatar
Sometimes a bad radiator cap can cause the system to bubble into the overflow. If three cap does not keep the system pressurized properly then it can run hotter.
Try a new cap as well
Old Dec 23, 2014 | 07:58 AM
Former User's Avatar
If the engine is running hot, then it's overheating.
Start here:
https://honda-tech.com/honda-civic-d.../#post39830585
he said that he thinks the head gasket is bad?...Also I think there is air in the system which I will bleed because I hear bubbling under the dash
Rent the Block Tester kit from AutoZone.
Old Dec 23, 2014 | 08:20 AM
Okay thanks a lot guys I'll give it a shot!
Old Dec 23, 2014 | 10:33 AM
poloboy4's Avatar
I would change the fan switch if I was you I had mine go out on my old em1 and it finnaly stopped working and did the same thing good luck
pcu
14
Aug 24, 2011 05:21 PM
OogalyDoogaly
Oct 31, 2010 11:09 AM
Dodger2940
Jul 25, 2005 03:50 PM
92integraVTECgsr
Jul 23, 2005 03:11 PM
brixity
Aug 27, 2004 07:38 PM
