where to apply hondabond on valve cover gasket
so i am replacing my valve cover gasket since last time i did it i did not put any hondabond and now it leaks around the valve cover.
where exactly do i put hondabond? all around the gasket or just on the corners?
and which type of hondabond do i use for this? hondabond 4 or hondabond ht?
just a small dab of hondabond ht in the corners where the cam hump is (less is more),be sure to replace the rubber grommets on the holddown bolts as these are what set the tension on the gasket and using old compressed grommets can lead to leaks . also replace the sparkplug tube seals
miksew
13
Oct 20, 2006 05:48 PM
type Gendy
10
Sep 6, 2003 10:44 AM
