car drips antifeeze from thermostat
Old Dec 18, 2014 | 02:59 PM
boostingvtec's Avatar
Default car drips antifeeze from thermostat
Car is dripping antifeeze from thermostat i just put a new thermostat and when I put the antifreeze I saw it was leaking from where the bolts hook to the thermo I tighten the bolts as much as I can and still does that
Old Dec 18, 2014 | 03:07 PM
Tony M.'s Avatar
Default Re: car drips antifeeze from thermostat
When you installed the new thermostat dd you clean all the crud build up aound the seal, and use a little gasket maker when putting on the new one?
Old Dec 18, 2014 | 03:48 PM
Former User's Avatar
Double check your installation. The gasket wraps over the thermostat and must be properly aligned.
Also post car and engine information to avoid thread closure. See forum Rules.
Old Dec 18, 2014 | 04:21 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Also of note, if you did not buy an OEM thermostat with gasket it most likely doesn't have the alignment nub(s) the OEM one does. The rubber post(s)/nub(s) is used for proper alignment and most after market trash doesn't have it so alignment is a royal PITA with anything other than OEM.
Pictured below is the nubs on an OEM D15B7 thermostat gasket that I need to put into my wife's car:
r berq
Oct 10, 2012 03:19 PM
single_slam
Mar 5, 2012 10:20 AM
Ohmster
Jul 4, 2008 09:52 PM
bb4socal
Nov 23, 2007 08:01 AM
crxvtecturbo
Jul 5, 2005 05:59 PM
