car drips antifeeze from thermostat
Car is dripping antifeeze from thermostat i just put a new thermostat and when I put the antifreeze I saw it was leaking from where the bolts hook to the thermo I tighten the bolts as much as I can and still does that
Re: car drips antifeeze from thermostat
When you installed the new thermostat dd you clean all the crud build up aound the seal, and use a little gasket maker when putting on the new one?
Double check your installation. The gasket wraps over the thermostat and must be properly aligned.
Also post car and engine information to avoid thread closure. See forum Rules.
Also of note, if you did not buy an OEM thermostat with gasket it most likely doesn't have the alignment nub(s) the OEM one does. The rubber post(s)/nub(s) is used for proper alignment and most after market trash doesn't have it so alignment is a royal PITA with anything other than OEM.
Pictured below is the nubs on an OEM D15B7 thermostat gasket that I need to put into my wife's car:
single_slam
03-05-2012 10:20 AM
Ohmster
07-04-2008 09:52 PM
