94 ej1/b18b1 swap -- problems after head swap
Old Dec 16, 2014 | 05:27 PM
EvoFusionsEJ1's Avatar
Default 94 ej1/b18b1 swap -- problems after head swap
Hey guys well first post for me on the forums.. Anyways I have a 94 ej1 ex I put a b18b1 swap in it ran great for a while then my bolts that hold the cams down with the cam caps... There's 24 of them 14 of them snapped so I removed that head got another head an put that on came off another b18b1 motor I didn't change the intake manifold put ARP head studs in put the head all back together and then realized the sensors on the intake manifolds were different so I hooked it up no hoses exposed anything got it up and running ran great for about 2 weeks.. Now here's where my problems started.....
Reving won't go past 4300rpm
When I start the car i have to hold the gas pedel down a little bit or the car won't idel
Sometimes after the car warms up it will idel
Runs shitty spits and sputters
Say I pull up to a red light or stop sign the car will just stall will crank but won't start up
Go crank it hours later starts up perfect
It seems like the car is not getting gas or something I really don't know would really appreciate it if someone can give me some ideas so I can get my baby back on the road thanks
Old Dec 17, 2014 | 05:25 AM
Former User's Avatar
Default Re: need help 94 ej1 swap problems? after swap
Post all CEL codes.
What head did you install -- post the head code.
Old Dec 17, 2014 | 05:28 AM
Default Re: 94 ej1/b18b1 swap -- problems after head swap
Where do I locate the cel codes I know normally its under my passenger side carpet where my ecu is but like I said the car is swapped so idk how to check the codes
Old Dec 17, 2014 | 05:31 AM
Click the Codes link in my signature.
Also post the head code.
Old Dec 17, 2014 | 05:32 AM
Its just another b18b1 head off another motor nothing was different but the intake manifold
Old Dec 17, 2014 | 05:33 AM
What was different about the IM? What engine did it come from? Please give details and post clear pictures.
Idk where your signature is sorry I'm really new the this fourm and don't really know how to use it
Old Dec 17, 2014 | 05:34 AM
I took it off a 1997 acura integra its a b18b1 ls motor
Old Dec 17, 2014 | 05:45 AM
The question is why is the replacement IM different than the original one? Post pictures to show differences.
My signature appears below all posts that I make.
rx7_dude2003
Feb 6, 2012 09:51 PM
Nate13
15
Dec 16, 2009 10:50 AM
Hondaddicted
Feb 7, 2004 08:33 PM
