brake leak that progressed
Old Dec 16, 2014 | 08:43 AM
Rick Baum's Avatar
Default brake leak that progressed
So, I haven't looked under the car behind the tires yet for leaks but I am a new owner of a 1994 honda del sol with a 1999 honda civic d16y8 engine in it.
Basically when I first had the car for a week it had a brake leak but the brake light would come on after about a week and a half to two weeks. I've had it for about 2 months almost and now i'm lucky if I make it all day before the brake light comes on.
When I checked under the hood I found the silver thing with the brake lines attached and obviously see leaks there but probably not enough to be my main leak.. I'd still would like to know what that is and why its leaking and why that close up pic of it has that circle with what looks like a bolt went there but rounded off, but its completely smooth...
And I also found that hose that i circled to be completly saturated in some sort of liquid wondering if anyone knows what that hose is for?
Thanks guys!
Old Dec 16, 2014 | 09:14 AM
eHMxhACk's Avatar
yippee-ki-yay
10 Year Member
Default Re: brake leak that progressed
Silver thing = brake proportioning valve and you'll need to replace it.
Hose = brake booster vacuum hose.
It looks like quite a lot of your engine is covered in liquid, most likely brake fluid.
eH.
Old Dec 16, 2014 | 09:31 AM
rockycat's Avatar
brake booster vacuum hose has liquid inside, may have a master cylinder leaking and being sucked into the intake manifold.
Old Dec 16, 2014 | 09:46 AM
Rick Baum's Avatar
alright and underneath the brake booster vac hose on the picture is a hose with the clamp on it, that is saturated as well any idea what that one is? Is this stuff covered if I found the link to the fsm or chiltons?
Manmeetsingh
May 20, 2014 08:06 PM
Dark_Templar
Feb 4, 2009 10:38 AM
94BlackRS
Nov 28, 2002 02:43 PM
SlowazzGSR
Jun 7, 2002 10:30 PM
