Civic w Gsr swap won't start!
Old Dec 16, 2014 | 07:21 AM
ColombianEk9Boy's Avatar
Default Civic w Gsr swap won't start!
I have a 2000 Civic DX hatchback with a 00 GS-R swap w p28 ecu.
My problem is when I put the key in to turn on I would have to prime it from cold start a couple times to actually even have it finally turn over, first time it always turns off then after a couple times it starts. I have spark, air is good, so Im thinking its the fuel pump/filter. Im using the stock fuel pump that it had for a single cam. Maybe this is the problem that not enough fuel is pumping or its clogged to make the engine turn over??? any information would be great. this is my first build. Thanks
Old Dec 16, 2014 | 07:46 AM
09chaplak's Avatar
Loves Tossing Salad
Default Re: Civic w Gsr swap won't start!
Correct me if I'm wrong but I believe you have the wrong ECU for your set up. P72 should be the one to use.
Old Dec 16, 2014 | 07:47 AM
Former User's Avatar
Does the P28 ECU have a GSR basemap chip?
Old Dec 16, 2014 | 08:03 AM
yes the p28 has a baseman for gsr, sorry if i didn't put that down
Old Dec 16, 2014 | 08:06 AM
Post all CEL codes.
When was the fuel filter last replaced? Have you measured the fuel pressure and tested the FPR?
Old Dec 16, 2014 | 08:31 AM
I haven't checked on the CEL codes and no I haven't measured the fuel pressure nor tested the FPR. The fuel pump was stock for the single cam.
Old Dec 16, 2014 | 09:42 AM
Start with CEL codes and go from there.
Old Dec 16, 2014 | 10:18 AM
tony_2018's Avatar
Fish Twig
cel codes...
Old Dec 18, 2014 | 12:40 PM
larios2281's Avatar
Seen this problem and 8 out 10 times its the ecu going bad
lilboxx
May 20, 2019 09:30 PM
JDMcivicSiEG6
10
Oct 20, 2008 07:25 PM
crxsiperf
Feb 5, 2006 10:54 PM
crxsiperf
Feb 2, 2006 05:31 PM
