Civic w Gsr swap won't start!
I have a 2000 Civic DX hatchback with a 00 GS-R swap w p28 ecu.
My problem is when I put the key in to turn on I would have to prime it from cold start a couple times to actually even have it finally turn over, first time it always turns off then after a couple times it starts. I have spark, air is good, so Im thinking its the fuel pump/filter. Im using the stock fuel pump that it had for a single cam. Maybe this is the problem that not enough fuel is pumping or its clogged to make the engine turn over??? any information would be great. this is my first build. Thanks
Re: Civic w Gsr swap won't start!
I haven't checked on the CEL codes and no I haven't measured the fuel pressure nor tested the FPR. The fuel pump was stock for the single cam.
crxsiperf
02-05-2006 10:54 PM
crxsiperf
02-02-2006 05:31 PM
