97 Civic with jdm d16a swap - smog blues
Old Dec 13, 2014 | 01:24 PM
spades614's Avatar
Default 97 Civic with jdm d16a swap - smog blues
Hey guys I have failed smog twice due to high nox . I have takenTwo test and the second I almost passed I just need some help to what I could look for .
This car is a 97 civic hatch i bought it with a blow motor swapped in jdm d16a but other than thats its stock
First test: timing was set to 12 btdc
Mph15: co2:14.3.
O2: .3.
Hc :28 max 49 .
Co: .29 max.57
No. 702 max 487.
Mph25: co2 : 14.1
O2 : .3
Hc:35. Max 66
Co: .36 max .55
No : 756 max 774
After that I change spark plugs to heat range 6 NGk they had 5 before . , changed throttle body for a known working one ( had problems with tps on my old one ). Pcv valve, and top o2 sensor (denso) went back right after
Second test at 12 btdc
15mph: co2 :14.2.
O2. .2. O2:.1
Hc : 11 max 66.
Co: .36. Max .57.
No: 553. Max 487.
25mph co2: 14.3
Hc: 11. Max : 49
Co : .39. Max :.55
No: 578. Max: 774
i went for a third time but this time i beat it for like 20 miles i got preety much same number except i got the hc down to 6 for 15 mph and 8 for 25mph and co went down to .23
i was thinking of changing thremostat and flushing the system and retarding the timing to see if that work could it be the cat any advice will be awesome
Old Dec 13, 2014 | 02:14 PM
spycker's Avatar
Default re: 97 Civic with jdm d16a swap - smog blues
Hmmm, pcv valve? what state are you in??? my Hc is 95, max 92 and my NO was 916, max is 776.....bought this car swapped with a d15bz1 and an auto trans, any tips to reduce my emissions is great
Old Dec 13, 2014 | 03:06 PM
Former User's Avatar
You might also try replacing the fuel filter, in addition to the thermostat. If the problem persists, the cat may be bad.
Old Dec 13, 2014 | 07:32 PM
B(eighteen)C's Avatar
turn your timing down to 10btdc. you are allowed to have a tolerance of +-2. and change your fuel filter or run injector clean or some kind
Old Dec 13, 2014 | 07:48 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
One trick you can do to refresh your cat is to do a citric acid bath. Pull your cat off and find a tub or bucket it will fully submerge in, then mix up a citric acid bath and let it soak over night. Drain it and you can blow air through it to dry it out a bit faster.
Citric Acid is one thing shown to refresh older borderline catalytic converters.
Google citric acid catalytic converter and you should find a wealth of information on it.
Scientists have performed lab tests showing that a heated bath of Oxalic/Citric Acid can effectively remove the contaminants from the Cat and not cause any damage to the Platinum/Palladium substrate. The Acid bath was shown to be able to remove over 85% of the Sulphur/Phosphorus that had poisoned the Cat, and dyno testing proved that the Cats had been successfully regenerated to nearly new efficiency levels. After reading all of the data and the procedures involved, I've decided that I will tackle this cleaning project myself " in the comfort of my own garage."
I now plan to pull both Cat's from the truck and treat them to a "warm bath" some time this week end. I'm going to use the gas grill in my backyard to keep the bath warm for at least 6 hours. I'll then rinse the cats in RO/DI water and reinstall them on the truck.
It appears you need to keep the citric acid warm.
Old Dec 13, 2014 | 10:09 PM
spades614's Avatar
The fuel filter has 2000 miles on it I put the filter on when put in the jdm motor . I also check fuel pressure 32 with vac line on 43 with it off
Old Dec 13, 2014 | 10:11 PM
spades614's Avatar
I thought retarding timing lowered nox not advancing it
Old Dec 13, 2014 | 10:14 PM
spades614's Avatar
The citric acid stuff sounds nice but I would be a bass because the cat is on the manifold .. I found an rsx cat and was thinking of just adding on just for smog and if it passes by Alot then I will just get the y8 header and keep the rsx cat
Old Dec 14, 2014 | 06:28 AM
spades614's Avatar
Will the there be to much back pressure if I leave both cats on or would it be ok ? Also would the rsx cat work well
Old Dec 14, 2014 | 10:20 AM
spades614's Avatar
Bump for the if rsx would work goon on a civic
Old Dec 14, 2014 | 11:03 PM
it should lower all your emissions just a little but seeing that youre failing in nox at 15/50, just retard it a little and that will should bring everything down a tad.
Old Dec 16, 2014 | 11:40 AM
baller status's Avatar
I agree with lowering the ignition timing to the low side of spec.
Also try running high octane, flushing the coolant, and you may even want to replace the thermostat. Some come with 82C (180 degrees) but 170 is the recommended temp.
Does your radiator fan come on? Are they using the dyno fan when running your emissions test?
NOx means your combustion temps are too high so anything you can think of to lower it will help.
Old Dec 16, 2014 | 02:31 PM
93egSLEEPER's Avatar
Run your car til empty. Do a 1:1 mix of methanol and regular unleaded. Drive to the emissions test and pass. Go fill your car up to full w/ regular unleaded and worry about the problems when you have the time and money. Done it with success 3 times now. Literally your car will blow zeros.
Old Dec 19, 2014 | 10:41 AM
spades614's Avatar
i will try it and post how it worked out thanks
Old Dec 19, 2014 | 10:42 AM
spades614's Avatar
i already replaced thermo stat and flushed and retarded timing to 14btdc but it went down only like 10 points and failed still lol
Old Dec 19, 2014 | 12:00 PM
spades614's Avatar
you guys think that e85 and and y8 injectors would work
Old Dec 20, 2014 | 04:57 PM
spades614's Avatar
I dont think i add enough Methanol to gas and i also unplugged the vac line from fpr to increase pressure ..... It did go down to 514 i needed 487 to pass i dont think i ran it enough either ....i think my car had like 1 1/2 gal and added 84fl oz of meth should i add more ?
Old Dec 23, 2014 | 06:52 AM
spades614's Avatar
ok i tested agian but different then my usual i added a gallon of meth (yellow heet ) and gallon 1/2 of 87 and fail but nox was at 732 before i had it at 514 with just 87 .. i also turn on the rad fan to be on and disconected the vac line from fpr to be at 42 new themostat and flush system i bleed the system .. i dont understand what could it be that cat be clogged ?
Old Dec 23, 2014 | 12:14 PM
spades614's Avatar
also co went up almost to failing so that menas its rich because of the fpr and rad fan being wired on nox is suposed to go down not up to 733 from 514 ? need help i have already taken 6 tests
ReSpade
25
Mar 23, 2014 09:22 PM
cantbetouched24
Sep 8, 2010 06:29 PM
Ruben19
Jul 7, 2009 01:18 PM
PandaBear
Mar 29, 2005 03:09 AM
erikz
Dec 1, 2002 04:53 AM
