Intake Question: How Do I Clean the Filter?
Old Nov 2, 2002 | 11:07 AM
slvrcivic97's Avatar
Default cleaning intake filter??
How do I know when I need to clean my intake filter?Are there any signs that show it needs cleaning or replacement?I have an AEM intake with the filter that came with it and was just wondering when i should clean it. Thanks.
Moderator: I meant to post this under tech. Sorry.
[Modified by slvrcivic97, 8:08 PM 11/2/2002]
Old Nov 2, 2002 | 11:09 AM
976's Avatar
976
New User
Default Re: --------------------------------intake question----------------------------------- (slvrcivic97)
Oh boy. Don't ever do what you just did! Never make a topic with those dashs (----).
Use the search, much easier than getting flamed.
Does the filter look dirty, has it been past 7,000 miles since cleaned. If then, clean it.
Old Nov 2, 2002 | 11:46 AM
Default Re: --------------------------------intake question----------------------------------- (VTEC VX)
sorry about the ------------, thanks for the info though.
Old Nov 2, 2002 | 11:59 AM
dwnthehatch's Avatar
http://www.knfilters.com/clningins.htm
tonyxcom's Avatar
To clean it, put get a bucket of bleach and water. While the car is running, dip the filter in the bucket. The motor will suck the solution through the filter and clean it.
Old Nov 2, 2002 | 12:08 PM
blackANESE's Avatar
Default Re: --------------------------------intake question----------------------------------- (tonyxcom)
Just buy the K&N Filtercharger recharge kit.
Old Nov 2, 2002 | 12:29 PM
jdmsol's Avatar
Yikes!
Old Nov 2, 2002 | 01:31 PM
ejprimo's Avatar
Default Re: --------------------------------intake question----------------------------------- (blackANESE)
do this or what tony said.
Old Nov 2, 2002 | 01:35 PM
black2kcivic's Avatar
Old Nov 2, 2002 | 03:21 PM
NYCz DA9's Avatar
LMAO!!
Old Nov 2, 2002 | 03:28 PM
BlackDeuceCoupe's Avatar
HT White Ops
You got it! Here's a pic of them cleaning an AEM filter on a NSX...
Old Nov 2, 2002 | 03:39 PM
dom93hatch's Avatar
Default Re: --------------------------------intake question----------------------------------- (BlackDeuceCo
Filter Recharger Kit - $10 from Autozone
[Modified by dom93hatch, 4:40 PM 11/2/2002]
Old Nov 2, 2002 | 04:37 PM
NYCz DA9's Avatar
Thats just mean y0!
Old Nov 2, 2002 | 05:13 PM
Happyman's Avatar
lol good times
Old Nov 2, 2002 | 08:19 PM
Danbu$'s Avatar
Oh come on, you can clearly see they are just testing the AEM water bypass valve
the only reason im even saying something is cause theres probabally somebody stupid enough to submerge there filter while the motor is on to try and fill it.
Take your filter off, clean it out with a hose, dry it, re- oil it, put it back on.
Old Nov 2, 2002 | 08:25 PM
97hb's Avatar
[Modified by 97hb, 6:09 AM 11/3/2002]
Old Nov 2, 2002 | 10:18 PM
johnnyblaze's Avatar
Default Re: cleaning intake filter?? (slvrcivic97)
take the filter off use a tooth brush, water and soap. clean it and then let it dry
Old Nov 2, 2002 | 11:16 PM
creasian's Avatar
dude, why didnt you post a bit earlier...what should i do with a water filled engine?
Old Nov 3, 2002 | 12:15 AM
Danbu$'s Avatar
"...what should i do with a water filled engine? "
It would make a nice oversized paperweight
or a boat anchor
Good job
Old Nov 3, 2002 | 03:07 AM
mycivicstoo(s)low's Avatar
Geez, don't you know anything? You're supposed to use gasoline.
Old Nov 3, 2002 | 03:46 AM
FifthGearOnline's Avatar
Default Re: --------------------------------intake question----------------------------------- (mycivicstoos
that reminds me...i need to clean mine!
MilanoRedDashR
Mar 9, 2014 09:34 AM
210jdmgsr
Aug 3, 2007 12:51 PM
sp0097
10
Mar 14, 2006 07:42 PM
Flux
Nov 6, 2004 07:09 AM
1Tym
Sep 23, 2003 09:00 AM
