Need help 95 Del Sol wont Start!!
Old Dec 11, 2014 | 04:50 PM
Reckless2469's Avatar
Default Need help 95 Del Sol wont Start!!
I am at a loss and so is the Honda Tech at the dealer
95 Del sol with Si SOHC motor will not start (Turns over)
No spark
Power to the Coil
No Switching signal to Coil
No Fuel pressure
Main Relay not working (Re soldered connections)
Check engine light just stays on indefinatly after turning on key.
We suspected the ECU and it had some damaged components (2 capacitors fried)
Tried another ECU and no changes.
Note***** Speed sensor wireds are melted. Honda Tech seperated them but still no change.
Old Dec 11, 2014 | 05:16 PM
Former User's Avatar
Default Re: Need help 95 Del Sol wont Start!!
^Fuse 24 is probably blown. Also check fuse 31. Voltage test them.
Clean and tighten the G101 ground on the thermostat housing.
Old Dec 11, 2014 | 05:35 PM
Ground on Thermostat is altogether missing.
I will ask specificly about those fuses tomorrow
Would any of those cause the ECU component failure?
Would shorted speed sensor connections damage ECU?
Old Dec 11, 2014 | 05:37 PM
Fuse 24 is likely blown, which fits perfectly with the symptoms and diagnostics, as does a disconnected G101 ground.
Old Dec 11, 2014 | 05:46 PM
So these issues would cause ECU to fry......
Thanks for the quick responce. I read your postings with "B18CivicHatch" and you sound like Honda car God!!
Old Dec 11, 2014 | 05:48 PM
Usually not.
Old Dec 11, 2014 | 05:56 PM
Could the speed sensor wires shorting together or to ground damage ECU
2 of the electrolytic capacitors in the ECU were definatly blown and had leaked goo onto the circuit board.
Old Dec 11, 2014 | 05:58 PM
Possibly. Be sure to properly repair the wires before installing a new ECU.
Old Dec 11, 2014 | 06:00 PM
Thanks for the input I will check these out tomorrrow.
Old Dec 12, 2014 | 05:27 AM
Egkid95's Avatar
[QUOTE RonJ@HT]Fuse 24 is likely blown, which fits perfectly with the symptoms and diagnostics, as does a disconnected G101 ground[/QUOTE].
I have the same problem, I have a 95 eg8. im going to try this also and see if it helps me. I new to the Honda scene so im trying to take in all methods and tricks to the trade ya know. thanks.
JesusGLS
Jan 13, 2013 04:59 AM
Hill4589
Oct 27, 2009 07:03 PM
t4tejas
Apr 30, 2008 02:27 PM
sharkeyd
Jan 16, 2005 10:31 AM
b16allmotor
23
Jan 4, 2005 04:05 AM
