96 Civic B16A2 swap - wont stay on
Old Dec 11, 2014 | 02:39 PM
stevevang's Avatar
Default 96 Civic B16A2 swap - wont stay on
1996 civic, b16a2 motor.
So i left the civic sitting for 2 days. After that time, i came to turn on the civic but it wouldn't stay on (was driving normally before, did not do any modifications during the 2 days). The first try, it would stay on for 30 seconds or so and then it'll turn off. Every try after, it will turn on but won't stay on at all. If i leave it for 20 minutes or so and come back and try it again, it'll do it all over again (first try staying on for 30 seconds).
Pin jumped it and codes thrown were Ignition signal output and throttle position sensor.
Checked for distributor for ignition. Replaced all 4 spark plugs to see if it would help, didn't help. Checked for sparks, there were sparks all across. Tried unplugging and replugging ecu. Tried opening throttle a bit while cranking. Sometimes, it will rev up but then die when let go of throttle.
Old Dec 11, 2014 | 03:54 PM
NotARaCist's Avatar
I never narc'd on nobody!
Default re: 96 Civic B16A2 swap - wont stay on
"There were sparks" is borderlining on diagnostically useless. Exactly what color was the spark? Was it the same on all four? You already have two CEL codes to work with - start working on those. Both could cause your problem. Do you have a voltmeter?
Old Dec 11, 2014 | 05:29 PM
Former User's Avatar
You have an OBD1 ECU. Which one?
Reset the ECU to see whether codes 7 and 15 return after cranking or running the engine.
Old Dec 11, 2014 | 05:47 PM
stevevang's Avatar
Im not sure what color the sparks were cause i was the one in the car cranking it. I tried resetting the ecu before checking for codes. I crank it and then engine revs up and then instantly goes down and dies like its too cold (running e85). Then CEL will flash and give me the codes. Even though im running e85 in the cold, on a normal cold day, it usually turns on within 3 tries max.
Old Dec 11, 2014 | 05:51 PM
Test the igniter unit (code 15) inside the distributor.
Advanced Ignition Troubleshooting - Team Integra Forums - Team Integra
Also check whether the TPS (code 7) on the throttle body is disconnected.
Old Dec 12, 2014 | 01:50 AM
grumblemarc's Avatar
The Grumpiest
If you're running E85 you are running anywhere near a stock setup. Perhaps you want to explain exactly what you have under the hood.
Old Dec 12, 2014 | 12:02 PM
stevevang's Avatar
I figured it out. After the car sitting 2 days, i found it that it was cuz some how, the center of the ecu got moist and frozed up. I gently got rid of the ice and tried drying it up with a towel. It runs now but it's like on limp mode, wont rev past 3k rpm. As of right now, im letting the ecu air dry.
Old Dec 12, 2014 | 12:07 PM
NotARaCist's Avatar
...wat?
That ECU is done. Replace it.
Old Dec 12, 2014 | 12:12 PM
tony_2018's Avatar
Fish Twig
Ice? Wow...I mean damn
Old Dec 12, 2014 | 12:31 PM
Figure out where this^ water came from before re-installing or replacing ECU.
Dry the wet ECU with a blow dryer.
Old Dec 12, 2014 | 02:08 PM
The Grumpiest
Originally Posted by NotARacist
...wat?
Double what?
Old Dec 15, 2014 | 04:52 AM
stevevang's Avatar
Default Re: 96 Civic B16A2 swap - wont stay on
After air drying, it runs normally now. The ecu lid was missing the middle screw so there was a hole and im guessing water somehow got into that and froze (winter over here).
Old Dec 15, 2014 | 04:57 AM
testify's Avatar
On vacation
So, just hoping it will never rain again?
Old Dec 15, 2014 | 05:34 AM
There should be no water behind the kick panel. There's leak that needs to be fixed.
Polecat12
Jun 4, 2014 10:14 PM
LWBJR
Jun 16, 2013 01:51 PM
Steveojonez2112
Jul 24, 2012 03:55 PM
blinx9900
30
Nov 18, 2006 05:45 PM
scrEaMO Kyle
Jan 25, 2005 07:55 AM
