Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
2006 Civic EX Heater is stuck on
Old Dec 10, 2014 | 08:46 PM
jjcard41's Avatar
Default 2006 Civic EX Heater is stuck on
Hi everyone. New to this site and I appreciate any help in advance.
So, was riding back from work and was getting warm and turned the thermostat **** to the cooler side and all I got was the same hot air. The blower is working fine, but I can't control the temperature. I tried turning it to cold with the AC but that didn't matter at all. Does anyone have any ideas or run into this problem? I guess I'm glad it's blowing hot air being that it's 20 degrees outside.
Thanks!
Old Dec 12, 2014 | 03:58 PM
97emsedan's Avatar
Default Re: 2006 Civic EX Heater is stuck on
That might need dealer support...
Old Dec 12, 2014 | 07:00 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
The air mix control motor is probably stuck in the hot position, allowing air to continually flow over the heater core to provide heat.
The air mix control motor is located under the center dash area, on the driver's side. Adjust the temperature setting, while checking whether the air mix control motor is driving the mix door.
It is fairly easy to replace if it is faulty.
The HVAC system has a self-diagnostic feature to check for any trouble codes. If you search this forum or the internet, you'll probably find the instructions to perform the self-diagnostic.
unclematt
Nov 14, 2017 01:09 PM
Guimba
Honda Civic (2001 - 2005)
Nov 13, 2009 01:14 PM
simplypinoyy
Feb 26, 2006 09:50 PM
crxtreme89h
Dec 12, 2005 03:17 PM
W.O.P.
Apr 14, 2004 04:44 PM
