Heater problem
My heater blows warm air when accelerating. I have to drive around like 30 min to get warm air, never gets hot. The longer I drive the warmer it gets. Problem started after I flushed cooling system last summer. Since then I replaced heater core, thermostat, water pump. My coolant disappears little by little but I don't see any traces of coolant in oil. I also feel like a temp gauge needle little bit lower than it should be. I thought there is an air pocket and i tried to fill it, but its either is not there or I can't get it out.
My car doesn't have a bleeder, but I ran opened a radiator cap and ran engine sometimes on high rpm to get air out. I still don't know if there is air pocket or not. I was thinking to replace cooling hoses with clear ones, to see if there is air in the system
If you are losing coolant, well you have a leak and need to find it.
For bleeding the system, there is a procedure for the V6's in this gen that you might want to follow just to be sure you get as much air out as possible.
Joshable14
Jul 20, 2015 10:10 AM
