NEWS: Introducing Hondata K-Pro Version 4
Old Dec 8, 2014 | 10:23 AM
mtber's Avatar
Icon7 NEWS: Introducing Hondata K-Pro Version 4
Pricing is still the same! To order click here!l
Faster and more powerful:
The KPro4 uses a faster processor with more capability than the KPro-III. This allows the KPro4 to perform more tasks without slowing down the ECU, like live tuning, output to a dash, flex fuel and advanced protection. Calibration uploads and datalogging from a laptop are also faster.
Enhanced on board datalogging:
The KPro4 has double the datalogging memory (64 MBit) of the KPro-III and can datalog at double the rate (100 Hz), giving an on board recording time of 10 - 220 minutes.
Faster upload & datalogging:
The upload time is 30% faster than the KPro-III, with a typical initial upload time of 7 seconds. Subsequent uploads are also faster, and live tuning can be used for instantaneous updates. Laptop datalogging is also 30% faster than the KPro-III.
Live tuning & autotune:
Main tables can be updated in real time, without affecting the operation of the engine. This allows dyno tuning without pausing to upload.
Autotune uses live tuning and a laptop to tune fuel tables as you drive.
Bluetooth:
The KPro4 includes Bluetooth for laptop programming/datalogging with a USB cable, and mobile datalogging.
Ethanol sensor input:
An ethanol sensor can be directly connected to the KPro4, allowing flex fuel operation, with adjustments to fuel & ignition tables performed automatically based on fuel ethanol content.
Speed sensor input:
A speed sensor input can be directly connected to the KPro4 and sent to the ECU. This is configurable to any pulse based sensor and eliminates the need for a stock speed sensor.
Dash & datalogging outputs:
The KPro4 has serial output (both TTL & RS232) and CAN output so that a dash can be driven from the KPro. The AiM MXL, Racepak & generic CAN outputs are supported.
Advanced Protection:
Advanced protection options use the KPro4 analog inputs and engine information to intelligently shut down the engine when the conditions might be dangerous to the engine.
Better wideband support:
The KPro4 can process a wideband lambda input (either analog or digital) and allow the ECU to run in closed loop from an aftermarket wideband without requiring the stock o2 sensor.
SJdc5
Feb 17, 2006 11:46 AM
NoVtecLs
Oct 6, 2004 05:54 PM
BLaCk-S
Mar 18, 2004 07:51 PM
VtecInteg95
Dec 11, 2002 08:29 PM
01-0720
Feb 15, 2002 07:33 AM
