Broken Hub or CV Shaft?
My daughters 03 accord has an issue that I am hoping is pretty minor. When put into gear, I can look at the driver's side CV shaft and see it spinning, the speedo will look like it is doing 40-55 MPH but the car will not move. I am leaning toward stripped splines in the hub or on the CV shaft, maybe a broken stub shaft on the CV. It was dark when I looked at it and I haven't had a chance to jack it up and pull the wheel off yet. Wanted to get some opinions and/or common issues related to this. Thoughts?
Not minor. Probably as BLKFLSH said. "Half" shaft axle. You don't need to take the wheel off. Pull the parking brake, put it in gear and let it idle, you'll be able to see what is and is not spinning.
DTS
Oct 6, 2006 08:11 AM
turboman
Feb 10, 2006 05:14 PM
