Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
Broken Hub or CV Shaft?
Old 12-08-2014, 05:24 AM
trailshredder's Avatar
Default Broken Hub or CV Shaft?
My daughters 03 accord has an issue that I am hoping is pretty minor. When put into gear, I can look at the driver's side CV shaft and see it spinning, the speedo will look like it is doing 40-55 MPH but the car will not move. I am leaning toward stripped splines in the hub or on the CV shaft, maybe a broken stub shaft on the CV. It was dark when I looked at it and I haven't had a chance to jack it up and pull the wheel off yet. Wanted to get some opinions and/or common issues related to this. Thoughts?
Old 12-08-2014, 05:58 PM
BLKFLSH's Avatar
Default Re: Broken Hub or CV Shaft?
I've seen broken drive shafts. I haven't seen any stripped splines.
Old 12-08-2014, 06:38 PM
94vtecmn's Avatar
Not minor. Probably as BLKFLSH said. "Half" shaft axle. You don't need to take the wheel off. Pull the parking brake, put it in gear and let it idle, you'll be able to see what is and is not spinning.
Old 12-09-2014, 04:08 AM
Tore it apart last night. Was the half shaft. Minor compared to a transmission re-build!
Old 12-10-2014, 12:09 PM
94vtecmn's Avatar
True on the better than a transmission.
Guess I can deal with the minor occassional vibration vs. this. I don't have the dampeners on my half shafts.
cricketracer
10-08-2006 05:09 PM
DTS
10-06-2006 08:11 AM
gurgle
03-21-2006 05:57 AM
turboman
02-10-2006 05:14 PM
Quick Reply: Broken Hub or CV Shaft?
