oil pump seal the same as front seal?
Old Dec 2, 2014 | 02:58 PM
Chargerhemi06's Avatar
Default oil pump seal the same as front seal?
I have a d16y7 with an oil leak coming from the timing belt cover. The valve cover gasket and cam seal have been replaced so it's not that. My question is...is the front crankshaft seal the same as the oil pump seal? or will I have to by a new oil pump?
Old Dec 2, 2014 | 03:11 PM
92ehatch's Avatar
Default Re: oil pump seal the same as front seal?
dThe front crank seal us the one behind the crank pulley and does sit in the pump. But there is another seal in the pump
17 most likely your issue 19 is also possible is the other seal
Old Dec 2, 2014 | 03:28 PM
If it's just 19, could it still cause oil to leak if the crankshaft seal is still good.
The reason why I ask is because my brother said he already replaced crankshaft seal.
Old Dec 2, 2014 | 03:36 PM
24TEN's Avatar
PHANTOM MENACE
They are independent but yes either can leak. Best bet is to clean it off and let it run, check to see where the leak is coming from.
Old Dec 2, 2014 | 03:49 PM
Thanks guys.
Former User's Avatar
#17 is the front crank seal you are asking about. It can be replaced without removal of the oil pump.
#19 is an internal O-ring. You must remove the oil pump to replace it.
Not shown is that the oil pump is sealed to the block by a bead of HondaBond.
Oil can leak from any of the three.
Therefore, you need to remove the crank pulley and timing belt covers to determine what must be done to fix the oil leak.
Old Dec 4, 2014 | 05:07 PM
belairbrian's Avatar
Originally Posted by RonJ@HT
#19 is the front crank seal you are asking about. It can be replaced without removal of the oil pump.
#17 is an internal O-ring. You must remove the oil pump to replace it.
Ron,
I think you swapped the numbers
Old Dec 4, 2014 | 05:43 PM
Originally Posted by belairbrian
Ron,
Fixed
1SickEG
Jan 28, 2013 03:54 PM
91(si)hatchey
Nov 6, 2009 12:32 AM
mattbatson
Jan 29, 2009 11:49 PM
nokturnal_munkeeboy
Jul 29, 2007 01:04 PM
NWHybrid
Jan 23, 2004 10:19 PM
