Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Would the 215/45 Azenis fit my car?
Old Nov 2, 2002 | 08:06 AM
Volcom's Avatar
Default Would the 215/45 Azenis fit my car?
1994 Integra RS with 16*7 Slipstreams (+40 offset). I couldn't get these wheels in the color that I wanted in a +45 offset. Is this going to screw me from ever being able to run the 215's? I've heard they run even wider than they measure.
Thanks
Aaron
Old Nov 2, 2002 | 12:51 PM
.RJ's Avatar
.RJ
Default Re: Would the 215/45 Azenis fit my car? (Volcom)
you could always use a set of wheel spacers....
Old Nov 2, 2002 | 01:02 PM
StageOne's Avatar
I have a set on my Integra with 16x7 +45 offset, and I dont have any issues. But I have a reasonably stiff suspension. With a +40 offset, it will push the wheels out a little more and you may rub on the rear fender lip. You could of course roll it or get springs that are stiff enough that it would not compress that much. What rates are you running in the rear and how low is the car??
A spacer would not help in this case as it would just push the wheels out farther.
Old Nov 2, 2002 | 01:07 PM
.RJ's Avatar
.RJ
Default Re: Would the 215/45 Azenis fit my car? (StageOne)
oops, i wasnt sure which side of the wheel was in danger of rubbing...
Old Nov 2, 2002 | 01:31 PM
Volcom's Avatar
I'm just thinking for the future. I don't have a suspension. Just wanted to see if I could run them. I thought maybe I screwed myself by getting the +40's. I've seen websites showing how to roll the fenders but never seen it done in person. How tough is it? Thanks again
Aaron
Old Nov 2, 2002 | 09:03 PM
Todd00's Avatar
I said I don't want a title!
If you lower, just don't drop the car too much and you'll be fine.
Old Nov 3, 2002 | 07:17 AM
Volcom's Avatar
Default Re: Would the 215/45 Azenis fit my car? (Todd00)
How much is too much for a daily driver and a weekend autocross car?
Aaron
Old Nov 3, 2002 | 10:31 PM
bretx0r's Avatar
215 45 ur car better be not lowered very much because thats a huge tire.
215 40 is approx the same size as a 205 45
Old Nov 4, 2002 | 03:55 AM
CivicSiRacer's Avatar
Default Re: Would the 215/45 Azenis fit my car? (bretx0r)
I rubbed with 215/45x16" Azenis on 16x.5" wheels. I know Pat Goss has 16x7" 42mm offset Volkt TE-37s and more negative camber and lowered (2" approx) and he doesn't rub with his Integra GSR.
Old Nov 4, 2002 | 04:09 PM
Volcom's Avatar
Default Re: Would the 215/45 Azenis fit my car? (CivicSiRacer)
What size wheels do you have? That's good news about Pat Goss having his GSR lowered running the huge azenis and not rubbing. those will probably be my next autox tires for sure!
Aaron
Old Nov 4, 2002 | 04:18 PM
Reread my post again I already said the size
Old Nov 4, 2002 | 05:15 PM
frogsr's Avatar
would anybody be kind enough as to post a pic, please? i just want to see and compare... thanks in advance.
Old Nov 4, 2002 | 05:21 PM
Volcom's Avatar
so what size are those wheels again? 16x.5"?
Old Nov 5, 2002 | 03:36 AM
I would think you would be able to figure it out 16x.7.5".
Old Nov 5, 2002 | 08:52 AM
Volcom's Avatar
I'm sorry, I didn't figure it out.
Old Nov 5, 2002 | 10:36 AM
vwong's Avatar
I'm running 215/45R16 Azenis on 16x7 +42mm Volk SE37K in my Integra. I don't have rubbing, the car is dropped approx. 1.75".
Here are couple pics, probably not a good angle to show the rims and kinda dark at the rim areas.
original size: http://www.imagestation.com/picture/...7.jpg.orig.jpg
original size: http://www.imagestation.com/picture/...8.jpg.orig.jpg
Old Nov 5, 2002 | 02:45 PM
Volcom's Avatar
Default Re: Would the 215/45 Azenis fit my car? (vwong)
Perfect! That's excatly what I wanted to see and hear. I want to run those tires after the Kumho 712's wear out! Thanks again for the pictures.
Aaron
Old Nov 5, 2002 | 04:11 PM
frogsr's Avatar
vwong, thank you also for the pics. much appreciated, and a very nice car at that!
Old Nov 6, 2002 | 09:03 AM
owen_the_soyboy's Avatar
Default Re: Would the 215/45 Azenis fit my car? (frogsr)
vwong, very nice car at that!
Old Nov 6, 2002 | 10:24 AM
vwong's Avatar
Default Re: Would the 215/45 Azenis fit my car? (owen_the_soyboy)
Couple more pics, but these are huge.
[Modified by vwong, 11:25 AM 11/6/2002]
Old Nov 10, 2002 | 06:48 PM
Volcom's Avatar
Thanks again for the great pictures! I will go with the azenis after I wear out the Kumho's
es_squared
Oct 9, 2008 02:45 AM
matt94z
Aug 7, 2008 05:03 PM
FrostyDC4
Oct 1, 2004 05:40 PM
bhcvc
May 24, 2002 01:16 AM
MikeD
Jul 24, 2001 09:05 AM
