2000 Civic Si with B20B block/B16 head - no start sometimes
Old Nov 30, 2014 | 12:35 PM
chaoslord's Avatar
Default 2000 Civic Si with B20B block/B16 head - no start sometimes
My lil brother bought a used 2000 Civic Si with a rebuilt B20B with a B16 head with a Skunk2 Pro intake and 70mm throttle body, and a DC Sports 4-2-1 header and Greddy cat back exhaust. The car starts and runs ok when cold some times but when it warms up it leans out and stalls then will not restart. When you try to restart it it some times pops like a small back fire and gets hard to turn over for about a second or 2 then goes back to cranking and no starting for a day or 2. I have run my OTC I-Pro scanner on it and logged the data from the engine and only can find lack of fuel with the O2 sensors and I have a brand new AEM wide band O2 guage in the car to follow as well. The fuel pump turns on for prime and primes 45 psi for fuel, I checked the timing belt and distributor settings along with the Apexi VFAC settings plus plugs cap and rotor and they all look good. MAP and TPS look good along with the air temp sensor coolant temp is good too. If anyone has any ideas for me to look for I would greatly like the help.
Thank You
Old Nov 30, 2014 | 12:45 PM
NotARaCist's Avatar
I never narc'd on nobody!
Default re: 2000 Civic Si with B20B block/B16 head - no start sometimes
VAFC? Problem #1 right there. Take the car and get it professionally tuned. There is no stock ECU for a B20VTEC, because that is not a stock motor.
Old Nov 30, 2014 | 12:57 PM
chaoslord's Avatar
Problem is in MA where I live we need an inspection sticker and the factory ecu has to be in the car for the OBD2 scan so the registry sees the factory ecy with vin number in it up and running with no engine codes.
Old Nov 30, 2014 | 12:58 PM
chaoslord's Avatar
ecu
Old Nov 30, 2014 | 01:13 PM
NotARaCist's Avatar
Then your little brother is fucked. He could try a GSR ECU, which would be closer, but there is no factory ECU that will run a 2 liter, B series, VTEC motor 100% correctly. It has to have the same VIN, too? That's...are you sure about that?
Old Nov 30, 2014 | 01:19 PM
NotARaCist's Avatar
Massachusetts Vehicle Check
Going through that, nothing says that the VIN in the ECU has to match the VIN of the car. It only says that the VIN on the firewall/dash has to match the VIN on the registration. Give a GSR ECU a shot, see if that helps. You might have to do some creative wiring to bypass the butterflies, but I'm sure there's a way to do it if you put the time and effort into it.
Old Dec 1, 2014 | 09:09 AM
tony_2018's Avatar
Fish Twig
Default Re: 2000 Civic Si with B20B block/B16 head - no start sometimes
Run usdm obd2a p72 ecu or find a usdm p73 obd2a ecu. Do not attempt to try an usdm obd2b gsr/type r ecu because they have the immobilizer chip. Hope to god the em1 still has all of the emissions stuff in there.
Mrintimidator33
Jul 19, 2018 08:01 AM
chaoslord
Dec 1, 2014 05:26 PM
hoonigan21
25
Sep 27, 2013 10:33 AM
hoonigan21
Engine Management and Tuning
Aug 11, 2013 05:49 AM
1jinxednoob
Feb 25, 2005 06:42 PM
