Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
engine knocking, plz help
Old Nov 26, 2014 | 04:32 PM
Hugo Rego's Avatar
Default delete post.
Old Nov 27, 2014 | 01:32 PM
andoxviii's Avatar
Default Re: engine knocking, plz help
After a HG swap huh?
If the noise wasn't present before the HG was replaced, your mechanical timing may be off. I'd look there first.
Is the check engine light on? If so, did you pull the codes?
Old Nov 28, 2014 | 02:02 PM
Hugo Rego's Avatar
Second problem, replaced the battery
Old Dec 5, 2014 | 08:40 AM
Humphrizzle's Avatar
is the head gasket on backwards/upside down?
Old Dec 5, 2014 | 07:29 PM
Hugo Rego's Avatar
It is in the right position, cuz u can only assemble the engine with hg in the right position and because I can still drive I assume its fine in that parameter.
Now for what I read, my engine is a 2003+ and my civic is a 2001 model, which means the hg can differ having egr or not ... the thing is the idle always stalling when I break after warmed up.... i dont have any of the problems when the engine is cold.
Old Dec 6, 2014 | 09:22 AM
take off vc and camshaft and check for damage.
Old Dec 7, 2014 | 08:56 AM
Hugo Rego's Avatar
The thing is the car runs fine until I get to stop signs, and Im not mechanic inclined so It would be hard for me to do that kind of job i guess. I want somethig I can try like sensors or som stuff on the easy side.
Ty for the help
99accorder
Oct 5, 2011 05:58 PM
tarheels1
Jan 17, 2010 06:38 PM
kikoman
Oct 14, 2009 02:59 AM
zemogregor
Feb 28, 2008 06:11 PM
