93 Civic DX Automatic - Ignition problem.
Old Nov 26, 2014 | 12:17 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Default 93 Civic DX Automatic - Ignition problem.
Car: 1993 Civic DX Hatchback
Automatic Transmission and Power Steering
D15B Carb Block and Head swapped in, everything else stock
Car is starting to have starting issues.
As of late everything works normal with fuel pump priming and CEL going off after two seconds but you turn to III (start/crank) and the environmental lights go off but no cranking happens.
I found if you push the key in (key cylinder depresses some) when you turn to III it cranks over. Before you didn't need to press just try a time or two.
I found this thread that was pretty much useless.
Found some good youtube videos on how to get the whole assembly out.
And I found this part with lifetime warranty on ebay:
92 93 94 95 Honda Civic Ignition Switch Wiring New Lifetime Warranty | eBay
I was wondering if anyone knows off hand if it would just be the electrical part of the ignition switch or if it would have anything to do with the mechanical aspect of the assembly.
The lock cylinder itself operates normally as far as I can tell.
Old Nov 26, 2014 | 12:50 PM
tony_2018's Avatar
Fish Twig
Default Re: 93 Civic DX Automatic - Ignition problem.
Yeah, sounds like the ignition switch. Its possible to replace it without replacing the key cylinder. Best take it apart and take some pics.
Old Nov 26, 2014 | 01:15 PM
Former User's Avatar
Yes, but test the switch (likely bad).
Old Nov 26, 2014 | 07:05 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
The joy of intermittent issues.... When the car was picked up today from the body shop it had zero issues.
Will have to start checking it on days off to see if it's acting up and do those tests.
Will report back the findings once I have them. Currently it will test out just fine.
Not sure if it's relevant but seems to be worse in colder temps.
Old Nov 29, 2014 | 01:33 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Okay, it's bloody cold as hell out there today and so I drug my 10mm socket with extension down to the car along with my screwdriver and multimeter.
Before I get started I try and start the car and once again, all works except the cranking in position 3.
So I close looped the SRS and pulled both the 5p and 7p brown connectors under the dash.
All continuity checks for position 0 (key in check), position 1 and position 2 all check out a-okay. I even checked the snap back into position 2 issue and it never faltered in position 2.
All position 3 continuity checks failed. I then plug the plugs back in, try cranking the car for nothing, then push in on the key firmly and it cranks over and fires right up.
I pull the plugs again and could not get any of the continuity tests to fail again.
Love the intermittent problems.
Anyways, based off of that it definitely looks like a flaky ignition switch. I don't believe spraying contact cleaner (electrical cleaner) into the key hole will even remotely get close to the ignition switch. I'm doubtful there is any easy way to get cleaner in that part without ripping into it a fair amount.
Anyways, thanks everyone for watching.
Old Nov 29, 2014 | 06:50 PM
tony_2018's Avatar
Fish Twig
If you take it apart you can clean the switch itself with electric circuit cleaner, than use di-electric grease. Put it all back together and it should keep you going until you can purchase another.
nizmo_max
Feb 15, 2015 03:05 PM
Vincent Gingras
Jul 5, 2013 12:26 PM
Declectic
Apr 1, 2013 12:36 PM
vtecpoweredsol
May 20, 2010 08:54 AM
