How would you plumb up a b16 coolant expansion tank?
So with my radiator being in the front of the car and the engine in the back, i need to figure out how to plumb up a coolant expansion tank. Any thoughts on how you would go about this? Where to run the lines to and from? Maybe one from the heater core outlet on the engine?
Re: How would you plumb up a b16 coolant expansion tank?
Are you also running an external pump, or using the stock one? Or both? You're going to have a lot more coolant mass to move around. Good news is that should allow you to keep a smaller radiator.
That's just an overflow tank there, I would run a swirl pot setup especially with that much line. I would say top neck of motor --> swirl pot (at highest point)--> radiator top --> radiator bottom --> external pump or motor inlet. Use as much aluminum as possible, it will help dissipate more heat, stays in place, and is lighter than coolant hose.
My $0.02
Using the stock pump which should work well i think.
No that would be the correct one to use for an expansion tank. I asked Saldana (they made my radiator).
where is the highest coolant point on the B16. Throttle body? I cant run to the radiator since it is in the front of the car so i need connections in the engine bay.
