Disc brake conversion ef hatch
Wanted to know if anyone has an experience doing the conversion i have integra da trailing arms is there anything else ill need i heard using a da brake booster and proportioning valve just wana know what to get
Yeah a simple google search of "crx rear disc conversion" but if you just do the rear disc conversion and keep the front crx brakes you would need a 2040 prop valve out of an 90-91 crx si. I would just upgrade the fronts to DA knuckles and then use the 4040 prop valve and DA booster and master cylinder along with the DA rear brakes.
If youre going to upgrade the master cylinder I'd suggest a DC 1". I believe you have to change fittings for the DA. DC is a bolt in affair just have to bend the line a little
CrAzE191st
Aug 30, 2010 05:31 AM
asianman139608
Oct 26, 2009 07:21 AM
juanito297
Nov 26, 2008 11:09 AM
