I need some help. I have a Honda accord 2001 lx 4 cylinder. It had a squeaky front right strut, so I replaced the strut and assembly. The problem I am having is getting the axle to move up so it can be reconnected to the upper right control arm. The axle appears to have dropped about 3 inches from it's ideal position. How can I riase the axle, so I an connect it to the upper control arm? See image
If you have to raise the knuckle you can just put a jack under the lower control arm.
What I do is lift it up into the upper ball joint. Then use a jack to lift the lower control arm until the knuckle top mounting circle is level with the ball joint. Then tighten the castle nut and slip in the cotter pin.
If you just need to raise the control arm and knuckle, do as Ser Manny stated.
If you need the knuckle to go in towards the engine more, but can't. Most likely the inner CV joint dislocated. You will need to gently work it back into its cup and then you will be able to line the upper BJ to the knuckle.
And in future, do not allow the brake hose or ABS wire to hold the knuckle in place. This can damage both. ABS sensor is not too much of a concern, but stress like that on the hose can cause it to rupture, tear, or leak at the swedge fitting. And we all like working brakes.
Great tip and yes it worked I managed to get the two to join. But i think when I hit it with the hammer to get it off in the first place it cause the upper bolt to be stripped, so when I try to pit the nut on it just stops and then the nut and bolt spon together. I can't get the nut to go past the hole for the cotter pin to be inserted. What can I do using basic tools to get the nut on?
thats a common issue in those castle nuts. You can try holding the area where the boot is with vice grips and tighten it. But you may also damage the boot. I usually use an impact gun and hope it works haha
Stud is a bit tricky as the hole(s) through the stud combined with the worn threads from corrosion can easily make the nut thread on cockeyed. Back off and gently thread it on by hand, then use a jack to raise the control arm up to fully seat the upper ball joint. Use one hand to force the upper control arm/bj down while tightening the stud nut with a ratchet.
If the first thread or two are knackered, file them down a bit if the stud has been musroomed. If the nuts threads are fubarred purchase a new one. Don't force/spall the threads.
Thanks, I filed the stud down one thread , fortunately the stud was not mushroomed. The applied car to get rid of the rust and used a Drexel to brush off the rust and dirt. Afterwards, it went on easily, I hand tightened it and tightened with a ratchet. Thanks again
I'm having the same issue and one of the issues is that my 2001 Honda Accord is non-abs but I recently replaced the axle about a month and a half ago and when I bought it it came with an ABS ring on the axle and then just two weeks ago I replace both front struts and now my right side axle does not fit and I did Jack use the jack to jack it up got it on to the upper control arm but it's driving real funny like if it's not properly installed or something the axle can I remove the abs ring on the axle and it still use the axle
